Another thing I have going on with my '97 K1500 is with the brake pedal / brakes....
I have had the rotors and pads replaced recently due to rotors being warped / untrue.
The issue was present before and after this.
When I brake...the pedal has a pulse / tempo feel.  It doesn't go to the floor or seem hard to press.
I have to press the pedal more for it to stop the pulsing but that makes the truck stop much quicker which isn't always needed.
I did replace the booster a few years back, but I don't remember this issue being present before or after that part change.
When's the last time you've had the rear brakes checked?
Typically if the pulsation is only in the pedal, its from the rear brakes.  If its shaking at the wheel its the front.
The rear drums and shoes were check at the same time the front rotors and pads were changed.  They did change the drums but the shoes weren't worn enough to change....?
Was the check just shoe life or drum roundness?
Its not the ABS kicking in is it?
Both were checked.  Drums were out of round enough to need replacement according to the guy that inspected.  Shoes looked almost new...
It could be the ABS system on the fritz.
The truck will hop like a rabbit at times due to the brakes.
Has a grab, release, grab, release, feel even when apply the brake steadily.
Edited by bcrooms
Try clamping 1 brake hose off at a time and take it for a test drive, that may help you determine which wheel is the culprit,
Could this be an issue with worn out wheel cylinders on the rear?
No, a worn out wheel cylinder would just leak brake fluid UNLESS the truck sat for a long time in which case the pistons in the cylinders could be binding from corrosion so maybe, but it wouldn't cause a catch and release. Wheel cylinders are cheap so it wouldn't hurt to check
It's always had this intermittent brake bounce.... the last guy that changed the front rotors/pads and rear drums said it was as good as its gonna get for my truck...which I dont believe is true.  I should have smooth braking if all the brake components are operating as they should, right?
3 minutes ago, richard wysong said:
yes
It hasn't been smooth for quite a while.  I thought the last guy would be able to resolve it...but no different.
Have you determined whether it's the fronts or the rears causing it? to eliminate the ABS possibility, pull the fuse ,if it still does it clamp off 1 brake hose at a time to try to determine the offending wheel. I wonder if the "like new shoes" could be the wrong shoes, There were MANY brake options for those trucks
I would say the rear is the cause for the hop.  The fronts only have a grab/release pattern.
I can see and feel the rear of the truck bouncing up and down at times when I apply the brakes.
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
