This only happens in forward gear with everything at operating temp.  If I sit with my foot on the brake, I get this rattle.  It goes away as soon as RPMs change even slightly so it doesn't do it in Park (which is why I can't diagnose it myself).  Anyone else hearing this?
2024 with the 10 speed.
https://photos.app.goo.gl/edm33P9k5v4Fu1E4A
I was going to say there's a slight rattling noise when I have the HVAC on when I come to a stop (comes from the passenger side), but listening to your video that sounds nothing like it. I'd definitely get that checked out! Hopefully just something a little loose vibrating a bit.
I have read a couple of posts on here where people have mentioned having a rattle caused by a loose bolt on the coolant reservoir.
  • 5 months later...
thread necro time.
This was it!  One GM couldn't spare a $0.001 locking washer on the left-most coolant bottle bolt and it'd worked itself loose.
5 hours ago, No F-bdy Bs said:
Mine has a slight rattle in the top, left corner of the driver's door window seal.
That one drives me nuts.  Haven't been able to figure out how to fix that one.
23 hours ago, UWSkier said:
thread necro time.
The worst part is its been a well known thing since at least 2022.
If I press on it, it stops for a few minutes. Pisses me off because I KNOW I'd be wasting time telling the service writer. No chance in hell a tech could duplicate it.
Brand new 2500 gasser and when I drove it home from the dealer it was raining so did not notice it but mine rattles and I noticed the noise occurs when any pressure is applied to the steering wheel when at idle or any increase in any RPM. Could it be the hydraulic power steering? Sounds like a faint diesel clatter.
I have the same rattle...goes away around 1000 rpm.   I looked at my coolant tank and my only question is does the rubber bushing simply ride on the bolt (it is not snug) or should there be a nut there.   If I jiggle the tank you can hear the bushing slapping.  BTW this bushing is on the firewall.
Edited by AT4X Steve
I don’t think it’s supposed to have a nut. Mine does not have one there either. I’m thinking the noise is heat is just power steering pump and fluid flow…. only because my last vehicle was a 1500 with electric steering.
That's how mine looks.  My bolt on the bottle that threads in to the fender sheet metal from above was loose.  I pulled the bottle up tight to the side of the frame there, tightened that 10mm bolt down to reduce the load on that bolt with the bushing, and noise is gone.
So the bolt in the rubber bushing is centered in the bushing now?
Actually, not really centered, just not making noise because the bottle can't move anymore.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
