First time poster…. Long time lurker
I handed down my 2015 Silverado 1500 to my son last March, and it had a 7in RC Coilover/Shock Reservoir kit installed along with Bushwacker style pocket fender flares and 20in wheels with 35x12.50x20 wheels.
The wheels sit pretty flush with the pocket fenders.
unfortunately my son was hit by another vehicle in Oct and took out the front drivers side wheel and suspension.
its been a nightmare with insurance but they are finally starting the repairs today. Outstanding issue is that my wheel cannot be sourced to match, and there are no indicators on the wheel to show backspacing or offset.
insurance will only pay for one wheel, and I’m footing the bill for the other 3
anyone able to help me understand what backspace and offset I need to be looking at to get a similar flush look or maybe a .5in poke?
Considering your typical wheel brand like Fuel, Method, etc… same tires will be used (Toyo 35x12.50x20). I would switch to 18’s but I literally bought new tires two weeks before the wreck.
thanks in advance
On the back of the wheel, look for ET followed by a number. That number will be the offset in MM. To measure the backspacing, lay a straight edge across the edge of the wheel and measure to the mounting surface.
Unfortunately I don’t have access to the wheel or vehicle. The shop doing repairs looked all over the back of the wheel and didn’t find anything
I’ve asked the repair shop to try and take some measurements from the current wheel. Reached out to customwheeloffset and based on pictures, they are thinking 0 offset is what is probably on truck comparing some other trucks they have in there gallery. Also remembered I have to account for the knuckle lift that pushes the wheels out about an inch and a half by itself.
hoping a member here has a similar setup and can comment on their wheel size and offset
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
