Just had the truck in for its second oil change at just under 4000 Klm . They also did a tire rotation . Hmmm . They don't include the spare in the tire rotation . Is that normal ?
Also how do you like to do it ?  I have heard after the tires have had some miles on them and if you needed to throw the spare on it can put stress on the drivetrain as the spare has more tread on it . Is this a fact ? How concerning is this ?
Thank you
  • Haha 1
Thank you
Is that still a thing? I can’t remember the last time when my spare was the same as the wheels on my vehicle. Usually a regular rim or a space saver in a car.
Something tells me some day I will have a 12-year-old spare tire with 0 miles on it.  You could swap it in if you replaced the tires with the same brand/model.  Since my truck came with Firestones, that ain't likely! 😀
Perfectly normal!
We do RWD Cross Rotations every oil change, about every 5K miles.  Meaning, the front tires are crossed as they go the rear and the rears come straight forward.  The opposite is done with Front Wheel Drive automobiles.
4 hours ago, swathdiver said:
Perfectly normal!
I’ve watched discount tire rotate my tires for decades. Front to back is it. Never an x pattern. I don’t have unusual wear so I go with it.
Ok I’m going to jinx myself. I’ve never had a flat. Maybe it’s because I don’t wear my tires to the nub. I’ve had leaks on original truck tires running on ROWs before my KOs get on. I used to carry plugs and plug them. So I got spare tires that are pretty old. Non match the ones on the vehicle, only in size.
I can do mine by myself, but it is kind of a pain in the butt so I wanted to get an idea of if anyone would do it for like 20-25 bucks and I called discount tire and he said they do free rotations and I said well I didn’t buy my tires there and he said it doesn’t matter And I thought there must be a catch so I went in there and he said the balance was like $30 but the rotation was free and I just said do the free rotation without the balance and everything else was in perfect condition so I literally went in there and got a free tire rotation and it still drives down the road the same as before I had it rotated and I watch them do it. So I will definitely be going back in there for tires in the future.
Well I’ll be. Sitting here at Honda getting fluids changed in the Ridgeline. I just watched a tire rotation. Sure enough they crisscrossed to the back. I don’t think my last rotation at discount did that.
Okay Thanks for the replies fellas .
To be honest I have not even looked at the spare wheel to see what's under there
My spare is on an 18" steel wheel and my truck has 20" wheels.
When I rotate tires, I just pull out my 2 floor jacks and do one side at a time. I can rotate my tires is less time than it takes to drive to Discount tire let alone waiting for them to get to me. It also lets me inspect things like brake wear.
I prop up the rear axle on both sides with jack stands, and then use the floor jack to prop up one front wheel at a time so that I can move the rear tire up and cross the front tire to the opposing back position. Then do the same on the other side. Very quick and easy.
This would be the proper way to do it yourself. The guy above is doing it wrong. But it’s Bruce so it’s understandable.
  • Haha 1
Says the guy that brings it to a tire shop.
Jacking up by the frame in two places is wrong now? That's hilarious! You don't work on your own vehicle much I take it?
Edited by bruceb58
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
