4 hours ago, rdonarski said:
At least you were here on a warm day. -19 yesterday morning, -22 the day before
41 above by Monday. The cold keeps most of the rifraff out vs a place like Houston TX tons of crime and terrible traffic and humidity.
  • Haha 1
True. Drove through Houston last winter on a way to a cruise. Put that on my list of places never to go to again. Company up here in the wintertime is sparce and even in the summer people balk at the distance. Love the winter solitude.
They are using CAN injection devices. Also, they can use a two person method where someone stands close to your front door with a device that grabs your FOB signal and relays it to the other person's device near the truck door. Truck recognizes the FOB is present and allows access and engine...etc.
I keep my FOB in a faraday pouch at home. Can't really do anything about the CAN injection other than there is a device that taps into the fuel circuit of your vehicle and has its own FOB that enables/disables the fuel pump. Haven't looked much into that one yet though, only heard about it recently.
That sounds interesting.
  • 1 month later...
    • The BORA 3/8" spacers arrived yesterday along with the extended lug nuts. I got the front wheels changed out today, but was overheated and covered in sweat so bad, I figured getting both front wheels done was a win, and took a cool shower. Hopefully, I'll go out tomorrow morning before it gets into the 80+ temps and do the backs. After getting the first wheel snugged up, I backed out one of the lug nuts then hand turned to count threads. I believe I stopped counting around 12-13, so I think I'm good there.
    • My fullsize truck is averaging over 26mpg so I'm pretty happy with the increased fuel economy targets. When I had my gas Silverado (2020 5.3) it was averaging 21. Again, for a fullsize truck, that's very different from the 12-15 these things used to get 30 years ago.   Whine all you want, increased MPG is a good thing.
    • That is a fair point, and I think an OBD-first proof is probably the right next step. I agree that the value is not the hardware box by itself. The marketable part would be the software: always-on capture, baseline learning, event reduction, system-specific reports, and alerts. Also agreed that if an OBD device is always plugged in and has local storage, it should not miss the event in the same way that a scanner plugged in after the fact would. The only thing I would not want to assume yet is that an ELM327-class device gives all the late-GM data needed at the rate needed. Standard OBD live data, DTCs, freeze frame, Mode 6, VIN, and calibration information are definitely the right starting point. GDS2 also proves that a lot of useful ECM data can be viewed through the DLC without needing a DTC first. The question I need to test is whether the data needed for a useful GM V8 event report is actually available through the DLC, and at a useful sample rate: - misfire counts / roughness by cylinder - AFM/DFM state - oil pressure and oil temperature - fuel trims - voltage / reset context - U-codes and communication events - calibration / software information - whether these are standard PIDs, enhanced DIDs, Mode 6 data, GDS2-only data, or not available So I think the right benchmark is: 1. Build the OBD-only version first. 2. Keep it plugged in and logging locally. 3. Compare it against GDS2 / freeze frame / HP Tuners or another higher-end logger. 4. Measure which parameters are available and at what update rate. 5. Only justify ECM-side hardware if it captures useful evidence the OBD version cannot. So you may be right: the consumer product might simply be an always-plugged-in OBD event recorder with much better reporting. A question for you: when you say ELM327 devices can already deliver all the data needed, do you mean generic OBD Mode 01 data only, or GM enhanced data as well? For a useful GM V8 report, would generic OBD data be enough, or would you expect the tool to include enhanced items like misfire by cylinder, AFM/DFM state, oil pressure/oil temp, U-codes, and calibration information?
    • 87 down as low as $5.14 here... winning!
