Hey Everyone,
I wanted to add some Headers to the truck and was looking at these ones. My question is, without cats the CEL will obviously be thrown. What tuning options exist currently to disable that?
Thanks so much!
Headers
https://speed-engineering.com/collections/2019-2024-silverado-sierra-suv-exhaust/products/silverado-sierra-1-7-8-longtube-headers-2019-2024
Y-Pipe
https://speed-engineering.com/collections/2019-2024-silverado-sierra-suv-exhaust/products/silverado-sierra-y-pipe-2019-2024-5-3l-6-2l-truck-suv
24 minutes ago, WinnipegSilverado said:
Hey Everyone,
Thanks so much!
Headers
Y-Pipe
Its all going to depend on what year truck you have.
That being said, year?  Make?  Model?  You've linked the y-pipes but left out the details on what vehicle you are trying to put this on.
Here in the states it is a Federal crime to modify the exhaust before and including the cats. No inspections up there?
44 minutes ago, WinnipegSilverado said:
That might help eh!
2023 Silverado 5.3 RST
Current mods
Intake
AWE Exhaust
3/5 lowering kit
HP Tuners is the only outlet for tuning.  Not sure how it would be done with them being you are in Canada though as HP is in the states.
ECM is required to be unlocked or replaced with an unlocked unit on the 2022.5-current Global B trucks/SUVs with V8.
The E90 ECM service - GM E90 ECM Service (Global B) – HP Tuners
The TCM service if you plan for full ECM and TCM tuning - GM T93 TCM Service (Global B) – HP Tuners
Then you will need to find a tuning shop who can tune everything afterwards.  12 credits are required to access both modules from the tuning shop so there's another $600.
All that work and money for just about zero gains with headers unless you spend most of your time at WOT.
Edited by Silverado4x4
Plus HP Tuners can't fully delete emissions anymore. There will be background tables we can't access anymore. Sure the check engine light might stay off but there is likely cat tests and rear o2 sensor tests that will stay active in the background.
Headers to me aren't worth it when it going to cost you so much just to tune it.
Thanks for all the insight! Youre totally right its not worth the cost to delete the cats. I was just looking to get a different sound out of the truck and thought this would be something to try. I could always just add cats to their Y-Pipe if I really wanted to do it and not tune the truck.
You'd likely need tuning with aftermarket cats as well.  Stock ECM knows what data its looking for with the OE sensors and if its CARB or EPA/Federal cats.  You could install and may run into cat efficiency codes on a stock tune truck.
IMO, I'd start with post cat mods first.  Catback like Corsa, Borla, MBRP, etc.  Or a full muffler delete.
  • Thanks 1
What he said. Even the stock cats are high flow.
Not much if any gain removing or replacing the cats.  When you sell the truck, no cats can become a big issue.
I can't rember the name, but there is a plug-in that mimics a cat and tricks the ecm to thining it's there and ok.  Not sure if they will work on these trucks.
    • FYI, I used sq body headers on my 72 and they were a perfect fit with zero clearance issues with the rods and Z bar for the clutch  I agree with post on worn mount rubber
    • I do most of my yard work before 10. My summer walks are usually at Kroger’s. Inside and yes I’ll do light shopping. Usually by noon you don’t want to be outside from June to September. The mail box is a good walk. I’ll walk there about 3 times before the mail comes. My house has two floors if I feel I need to move I’ll do the stairs. I’ll walk down the lane to our rent house with clippers trimming branches along the driveway. There’s always something to do.
    • There is a sign at my chiropractors office that says, "Don't quit, take a break." Sound advice.    On a 65 degree day (F) I can still work pretty darn hard (I'm 72). On a 85 degree day with a good deal of humidity it takes me three days to do what in took at 65 degree in three hours. If I work to muscle exhaustion (back) it will take me days more to recover. Taking breaks to prevent that is most useful. A lift belt has been very useful in preventing both.    Minister was giving a talk the other night where he was speaking of age and he used a clock to illustrate the human lifespan and it's ability to task. 1 to 45 was the second hand, scurry about. 46 to 70 the minute hand. Slower but...71 and up the hour hand...Hummm....until that talk I felt more like the minute hand. 😭   Then he says, the most useful hand on the clock is the hour hand. Without it you can't tell time. (Hour of the watch). I felt a bit better knowing we over 70 are useful. 🥹
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
    • @newdude great info, thank you!   So opening the thermal bypass valve early (or all the time) would cause temperature to rise more slowly, but above 194F there would be no difference from normal operation?   It seems like the only practical ways to bring down the peak temperature would be to improve the oil-air heat exchanger in some way or increase fluid capacity?
