Technically not OEM, but identical design reproductions of the factory 22s. the wheels I wanted were only available OEM in chrome, and chrome is a no go!
So I guess the spec is these wheels are 9" wide, I'd really like to run a 305-45R22 tire on there, but when I shop for them seems the specs say the wheel size range is 9.5-11.5, just outside the spec. Anyone else running that size tire on the OEM size wheels? I have 285-45s right now, but they are fewer revs/km than oem, the 305-45 is nearly identical.
Guess I can reply myself 🙂 Saw plenty of posts online about people running the 305s on 9" wheels. also some about having to shop around for a tire place that will sell/install them. some refuse because even though it works fine, its technically outside the specs for the tires. I spoke to my local shop's tire expert, he says 305s on a 9" wheel is absolutely fine. so you might run into shops that won't want to accommodate you, at least one tire guru says its a perfectly suitable combination.
No issues whatsoever running 305/45/22 on a 9" wheel.  Go for it and never look back!
How close in diameter are these to the factory 22" tires in a denali?
Diameter is pretty close, its the width that might give you problems:
                                                       275/50-22               305/45-22                Difference
Diameter inches (mm) 32.83 (833.8) 32.81 (833.3) -0.02 (-0.5) -0.1%
Width inches (mm) 10.83 (275) 12.01 (305) 1.18 (30) 10.9%
Circum. inches (mm) 103.13 (2619.46) 103.07 (2617.89) -0.06 (-1.57) -0.1%
Sidewall Height inches (mm) 5.41 (137.5) 5.4 (137.25) -0.01 (-0.25) -0.2%
Revolutions per mile (km) 614.38 (381.76) 614.75 (381.99) 0.37 (0.23) 0.1%
I had 305/45/22 tires on my factory 22" rims that came on my 2025 GMC Sierra Ultimate before I changed them to OEM black rims.    Had no issues at all, no rubbing, ever.   Then switched quickly to the OE black rims,  same exact specs as the factory wheels.  Have had them on for almost a month now.   No issues at all.  Love them,  love the look and the ride is great.  Low noise too.
Nitto's are complete garbage. I got maybe 19k miles out of mine. They look great but in terms of a hybrid they wore down FAST like a M/T
Edited by Ryan Tierney
I had Nitto's on my Jeep and experienced the same thing. Quiet but wore fast. I will look at Michelin Defenders in 305r45/22 when I dump my stockers.
Had the defenders on my past Silverado SS, really liked them. great tread life, quiet, good ride. very solid tire. for the Denali I wanted stick to a sport truck/sport SUV tire. I have Toyo Proxes ST3 on it now, I’ve had several sets of those between the Denali and a couple Jeep SRTs. Great tire but did seem to wear faster than I’d like. I’m going to try the Yokohama Parada Spec X this time around just to make sure I’m not missing out on something potentially better.
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
