i am looking for a new new to me truck and wanted to ask for opinions on the new 10 speeds transmissions that come on the 24 up trucks
2 hours ago, jake111 said:
A/C on full blast.  On my old LLY the fan ROARED.  While my hearing kinda sucks, I can't hear or feel this fan . . . I'm assuming it's the fan that causes the engine temp to drop so dramatically.  Engine oil and transmission temps are much slower to respond so, no, they didn't drop directly.  But they also stayed in very normal ranges.  Again, I am impressed!
While not some large heavy trailer where your slowed right down on a hill and airflow vastly reduced which is the test that really shows the maximum that a vehicle can withstand ( and some literally come to die in that situation, hot day and a long grade ), I gather comparison wise this truck is doing a lot better vs your older duramax for a similar load and weather. I wonder if the fan on the gas truck is less aggressive due to the rpm the gas engine is capable of vs the diesel and may not sound off at a more midling rpm, just speculating. The cabs sound proofing would come into play also as I hate to admit as well that my hearing is not what it once was either, being around and operating equipment years ago with no access to hearing protection catches up. Being that the thermostat is listed as a 187 or 190 range unit I would be surprised if it was the thermostat on its own doing this, what you describe is like the reaction a highway tractor has when the fan clutch engages as the temp just drops back pretty quick if its on a reasonable temp day but with the semi it has a light on the dash that comes on to show that the fan is engaged due to how its being engaged. With a pickup with a mechanical fan with a fluid clutch I doubt there is any way of sensing what the fan is doing and also can't manually control its engagement like one can in a semi.
I am curious if you owned the LLY from new and the reason I ask is that bugs plugging up the condenser and in fact damaging the fins as well as whatever accumulates in the fins of the rad over the years takes its toll on cooling performance when the air can't get through even if the fan is howling away.
In any event I am glad to hear your gas truck which is the same unit I recently bought is capable of cooling in adverse conditions as my old half ton chev was pretty pathetic and that is just driving the truck not hauling a camper or pulling a trailer. I ended up putting in a thicker core rad and toying with the fluid clutch bimetal spring to get the clutch to activate sooner, I think that's the reason I made it through death valley without having a melt down and I also was real careful with air conditioner use being gun shy after my prior experiences with that truck.
I don't think anybody here wants to hear about the LLY overheating issues (and they can stop reading this paragraph!).  Out of the factory, LLYs overheated on long grades, especially when towing/hauling.  There were a gazillion posts/arguments/tests and many attempted solutions. First noticed my new 6 month old 1-ton Duramax had a problem when it went to 230*F pulling a 5000 lb. trailer uphill from the desert (west on I-8 towards San Diego) in 70*F weather.  Yes, the fan roared which only seemed to make it worse (more load, more heat).  Solution was to add an auxiliary radiator under the main radiator (behind the bumper) which tamed it (actually made it work the way it should have from the factory).  Mostly a problem for people west of Texas with long grades.
I admit to being an overheating weanie.  IMHO, cast iron blocks with aluminum heads (and maybe others, too) should never go over 220*F or there will be problems.
Yes, I am only hauling less than 3000 lbs. but it sticks up and catches a lot of air.  MPG's seemed to be over 12 at 60mph, probably 10 at 70mph.
I've just not been around the LLY enough to have realized they had that overheating issue and a neighbour that has owned I believe its an LMM  and still has that and then had a LML he sold recently and bought a first gen L5P, never happened to hear comments of running hot but then I haven't asked either. I imagine GM did some changes after the LLY and looking up some write up comments about the LLY, number one on that list of issues is overheating because of an undersized cooling system and that the fan clutch was not robust enough and resulted in overheating when under load. His L5P he bought used back in the winter and its a crew cab dually and bought it to haul a Northern Lite 10-2 and unless he put down a weight figure wrong he said he was at 14500 lb loaded for going camping but in any event he said for that load and wind resistance it just goes, very happy with the power it has ( was down to California this winter with it ).
Being that we are talking both diesel and gas in the same breath, the fuel mileage you mentioned, was that for the diesel. I'd be curious to know what your getting for mileage with your gas truck hauling the camper. Also unless I missed it, I don't know what your actual gas truck setup is, if its a one ton crew cab long box with single wheels or its a dually ?
That's the problem with what I bought when it comes to the idea of a camper, it would have to be a lighter unit and shorter to fit the short box as its the one ton crew cab with short box and single rear wheel. Just what fits a more all around pickup theme but unfortunately not a good base for a decent sized camper but would be fine for a reasonably sized trailer.
Overheating and be it pushing a unit that was never designed for the task even though they claim it is, there's no fairy that comes along and waves the magic wand to make the repair bill and being stranded along the road go away. I've heard comments for example of people from Colorado noticing travellers with Ford F150 eco boost trucks sitting on mountain passes with a trailer behind and she is all but done, wiped out the engine. High altitude density air doesn't cool as well but the turbo can ram in the air and make that engine put the power to the ground ... until it doesn't. No one wants to be the person in that mess far away from home so being an overheating wienie as you call it is what saves your bacon by being aware and taking action vs being a steering wheel holder and too busy trying go faster up the mountain then those around you.
Ooops, thought my signature said it all (and I just now changed it a little, added 4x4):
NEW: 2024 Silverado 2500HD WT 6.6L Gasser, 10-sp Allison, Dbl Cab, Long Bed.
Usually has 2007 Lance 835 Camper in the bed.
SOLD: 2004.5 Silverado 3500 SRW 4x4, D/A (LLY), Ext. Cab, Long Bed
The LLY had several shortcomings that contributed to "overheating".
1) The turbo inlet ("mouthpiece") narrowed where it angled into the turbo.  Solution was to replace it with an LBZ mouthpiece.  This would help but not solve overheating problems.  Probably helped more for EGTs.
2) Bigger or thicker radiators didn't necessarily help.  The problem was airflow through the engine compartment.  An aux radiator mounted below caught a separate air stream in/out, and you would actually have a block to keep those airstreams separate.
3) My thermo-fan always worked well.  Some people had problems with theirs.  Some tried electric but they don't move as much air.
With my LLY and this camper I came up with an all-around MPG guesstimate of 13.5.  Hit a little hill or headwind and down to 10.  Tailwind or downhill and it went up to mid-teens or even higher.
Only been on a couple of trips with the L8T, this last one 1000 miles that included desert, Sonora Pass (9624 ft., 26% grade in a couple of places), the California central valley, and grade from Bakersfield to Tehachapi.  The DIC says 12.1 mpg for the trip.  I didn't hand calculate but I believe it's pretty accurate (what have others found?) when I check it on just 1 tank.  Just like the diesel, it's very sensitive to hills and wind.  I'm happy with 12!!  Note: it seemed to get better after a few thousand miles; I'm only up to 5000 miles now.
If the L8T fan is the traditional thermo-clutched fan (it looks like it), it's the most consistent one I've ever seen.  206-207*F and it (or something) kicks in and down goes the temp.
Now, for my gripes.  Is there any way to do anything without starting the motor?  Like to look at the DIC stuff?  Presumably there's an override hidden somewhere to shift it out of park without starting, but it's sure not obvious.  When camping, I would like to shift out of Park, release the brake, and roll off the leveling blocks.
Edited by jake111
3 minutes ago, jake111 said:
Ooops, thought my signature said it all:
That's all my own fault, I seldom look at the bottom of each post as quite a few members I noticed had put their short vehicle description just under their name and I had done the same when I signed up as a member a few months ago and tend not to look down below ... oops !.
That is interesting about the engine compartment design now allowing through flow, the trucks may have been a bit lower on the underside but certainly lower at the top of the grill and underhood area I believe, you know how tall the front of your new truck is as reaching very far into the engine compartment is impossible and the physical engine ( not all the crap on top of the engine with the intake ) is way down there and that would change the airflow all right. I know in later years they talk about the duramax having a new and improved high capacity cooling system, I don't know if they really say much about the gas version but whatever they are doing seems to have promise with your findings and others on here and towing tests I've seen in Colorado on the mountain grades ( not talking about TFL though )
I tried looking up your camper model and did find some specs from back in 2007 but they don't talk about the weight, I see that model number is not made now but manufactures are always changing things anyway so the same model numbers can change drastically over the years. The only reason I was looking for the specs was to compare to older campers I was around as a kid, one my dad had and actually is still sitting in a shed on this farm and then a relates camper and truck they had. Campers back then did not have the false floor and tanks under it as that just jacks the height up all the more but these were full size campers otherwise in that over 10 feet long range from the front of box to the back of camper. If I am correct I believe my dads single cab long box with a standard trans and a 396 ( talking a 1969 GMC as this is a while back ! ) I think maybe he was getting around 10, the uncles crew cab single rear wheel with an automatic and a 454 was around 8, Like I said don't quote me on that but I think that was what was talked about years back and both were two wheel drive trucks. We were never flying down the highway, just going along and I am guessing 60 typically and maybe even a bit slower. Which brings me to a couple of questions, what speed do you typically drive with your camper ?. Also have you added anything to the suspension being that it is not a 1 ton like your diesel was.
I've heard of the Senora pass more lately, never knew anything about it the only time I was in that general area as I went from Death Valley up 395 to Lee Vining and over the pass into Yosemite that summer and then angled south west to Paso Robles and out to highway 1 and followed it all the way up until it turns back inland to 101 and hit up the various coastal redwoods as well, fantastic coastal scenery and wish I had been able to do the whole number 1 and spent a lot more time out there along the way vs always on the move to get back home to work, that is 18 year ago and you just got your camper as it donned on me.
Your question as to being able to do anything without starting the engine and the answer is yes. I haven't experimented much with it but presume the electronic park brake should operate in this setting as well, I just never tried it. As I see it there is a good side and a negative side to putting it into that mode as boy does it suck battery power like crazy and one doesn't want to put it into that mode for any length of time the way I see it anyway unless one has a decent sized battery charger on the battery that can keep up with that draw ( such as running diagnostics in that mode messing with a diagnostic tool ). So with that warning out of the way, what you do is have your key fob with you as usual and without pressing the brake pedal you push and hold the starter button. I don't know the exact time but it takes maybe 7 seconds for it to get into what they refer to as the run mode as the dash lights up just like the truck has started. WIthin that procedure the dash will tell you "press the brake pedal" because it thinks your wanting to start the engine but ignore that and continue holding the button and then the dash lights up and your in the mode and you let go of the starter button. Now its sucking the power like mad as the truck systems are alive and now without pressing the button you can press the brake pedal and wa la ... the gearshift will go to any position you want it to and would roll away unless the park brake was set or your foot is on the brake pedal. Remember that I don't believe you would have any power brake assist either. I assume that to get the truck set up to be flat towed ( I think they can be but not entirely sure of that ), I suspect the transfer case has to be put into neutral, nothing I have looked into though. So hope that helps but just don't do it on a steep driveway and back into the neighbours Ferrari F40 or something !. To turn it off you simply press the starter button as usual and it partly shuts down and then when you open the door everything should shut down.
Thanks for the bypass info.  I have held the start button for a few seconds, and/or hit it twice, which didn't work of course.  I will try the long hold . . . 7 seconds is a LONG time!  And then try the brake to get it out of gear.  After almost 60 years of driving I still kinda like turning a key instead (more starting control and so much simpler).
There's a lot more open space in the new truck engine compartment compared to 2004, and it's much higher.  I have to use a step stool to check the oil now.  I don't know how a shorter person can see over the hood (I'm 5'8" and it's sometimes a little challenging).  But maybe it's worse because I have about 2600 lbs. of camper in the bed so the truck sits level.
On the 2004 3500 I added an anti-sway bar on the rear and a heavier duty one on the front.  Also added Torklift Stableloads to the lower overload springs.  Truck still sat a little higher in the back than the front.  Without making any suspension changes on the 2024 2500, it sits level, rides better, and handles wind a lot better.  I sometimes consider adding Stableloads, but why if it's so well-behaved now?
The LLY liked to cruise at 63mph.  The L8T is comfortable at 70 or more, but sucks gas like crazy.  At 60 it generally gets over 12mpg, so I found 63 once again easy going.
For sure try the so called run position and yes to me its all idiotic as I am so used to a key and mechanical systems that don't have a mind of their own. There are so many modules/computers on new vehicles and its no wonder they need a larger alternator than ever before just to power all that crap, its not like the truck even has an electric engine fan like most small cars and suv's have these days. Just park on level ground or chock the tires to avoid mishaps. I never tried turning the steering wheel but I would like to hope that it takes the steering wheel out of lock mode. Sadly I know so little about my own truck and never will be able to grasp it all as its not like I have a shop manual and lots of hands on instruction on all the unique quirks about it. I am not even sure if the HD trucks automatically apply the parking brake if parking on a sloped surface, the half tons certainly will apply it if the driveway is fairly sloped as an every day on road example of what self thinking they will do.
Being that I am 6'4" I can check the oil but even at my height I am almost touching the fender to do as I reach over to get the dipstick, who would think a factory non lifted truck would be this high. There is no way I can reach the oil filler cap from the front without standing on something and then there is that goofy slant that the filler is on and there are elbow adapters out there to slide in and then use a specific funnel but sold in the states so instead I bought a specialty funnel kit with adapters and that screws into the cap hole and has an elbow on it that the made for it funnel fits into like a glove. I know some will think its ridiculous to buy a contraption like that but since I do my own oil changes I figured I may as well have one and make life easier. I have to stand on something but then can install the funnel and pour jugs in with no issue at all.
I was nodding my head as you went through the list of items you had done with your older truck to get the handling and carry ability to what you wanted, to have a unit that would handle decent on the road with the camper. I had mentioned older campers when I was a kid but back in 2006 my brother had bought a F350 crew cab dually 4x4 with the 6 litre diesel and then drove to BC to the factory to pick up a camper he had bought. Its not a brand that is made any longer but its a large unit but with no slides as he didn't want to deal with all that crap and even more weight. Well he soon discovered that this "big" dually could not carry that weight with its factory springs as he came home dragging his rear bumper ( not literally but figuratively ). He had a shop install two more leaf springs per side in the main pack and air bags. Well as the years went by and dealing with side winds and uneven roads, he found that unit to be quite unpredictable and a lot of stress to drive in the wrong conditions as it would have a mind of its own as to what direction it was going to go as it leaned over in gusty winds. He was almost ready to sell it and buy a different camper but I think most of the camper manufactures lie through their teeth and play games when it comes to what their campers actually weigh. Anyway he got onto the stableload idea and installed both the lower ones and the upper ones although the upper ones didn't do a lot since the upper spring on the Ford is pretty pathetic. The lower stableloads, we jacked the truck up and hung the axle down to the end of the shock stroke to cram in what we could manage to fit in and using prybars to gain all we could with widening the bottom overload spring gap. That definitely helped carry better as well as helped the stability. The fact is that airbags he came to realize and others have as well, they actually detract from the stability rather than enhance it, start pumping the air bags up and that takes weight off the leaf springs and instead puts it onto the somewhat mushy airbags that are prone to allowing lean. So like I said with the stableloads it was better and he also reduced the pressure in the airbags some and that certainly was an improvement. However it still could use more stability from side to side so I was diving into what was out there for aftermarket anti sway bars as his truck came with factory front and rear ( they always come with front ) units but they were just not up to the task, definitely that rear one was way under sized. I talked him into getting new bars for both ends ( another words throw the kitchen sink at the truck ) and I found the largest ones made for his truck at the time as this is a few years ago now, was from Roadmaster ( Hellwig for his truck were not as large ) . Bought them both and helped him install them and that just transformed the trucks handling along with the help of the stableloads. Who would have thought, the factory putting on anti sway bars for that very purpose and yet just not enough for a top heavy load. The rear bar is now 1 1/2 inches in diameter, its a chunk of iron.
The neighbour that bought his used 2023 crew cab dually duramax for his Northern Lite 10-2, his was not handling well and needed more carry ability as well as sway control and he threw in timbren's and from his claim so far he was happy with the ride and the stability. I was just shocked that GM is not putting an anti sway bar on the rear of the dually but they are available through the aftermarket. What surprised me is that his truck has what would be called a 3+1 lower main pack spring which is 3 main leaves plus the bottom tapered overload spring and then the upper three light overload springs that contact the frame pads. My truck has a 4+1 lower pack with 2 upper overloads. I presume your truck has the 4+1 lower pack and its not like I measured the neighbours leaf thickness but I almost get the idea that the more current 3/4 ton truck has a more beefy main spring pack than the slightly older one ton dually ( I've not looked at a new one ton dually on a lot to see what setup they have now ). There's a reason why your truck is not only carrying the load but that its not swaying ... that blows me away that its as stable as it is. But for some reason if you decided to do something extra, it might make sense to install timbren's and get a little more carry plus side to side stability at a low cost ( those stabilizer bars are very pricey up here ). and yet when your driving empty and there is a gap between the timben's and the axle you don't loose your empty ride like you would tend to a little with lower stabileloads.
I typed a lot there but thought you might find my brothers experience interesting with what was done to his truck to make it handle and also carry the load, and he flat tows a Jeep behind, that is where an engine brake would be very nice to have but his truck doesn't have that and one if the items that gas trucks never have vs any of the newer diesels.
I forgot to ask, do you go into manual mode and lock out the top gears with your L8T when hauling the camper as I find even empty that my truck doesn't have very much ability to hold 10t or even 9th for that matter up any sort of typical highway grade. I have only guessed that 8th or even 7th would have to be used to keep the transmission from constantly shifting up and down wearing itself out.
Funny you should mention hill braking assist.  2 miles from home on last trip, stopped for light on moderate uphill at light, took foot off brake and reapplied and it felt funny/hard.  Hmmm.  Repeated.  Hmmm.  DIC says something about Hill Braking Assist.  Oh, I usually turn that crap off.  I like to roll backwards sometimes!  This and my 2023 RAV4 hybrid don't like me to, sigh.
Yes, rear spring pack is 4+1.  Overload is engaged with camper, but truck is level and rides nice!
This L8T has a significant amount of torque, not as much as a diesel, but a lot.  It actually runs down the road at lower RPMs than my old LLY did.  It had no problems on steep hills.  Steep downhill obviously doesn't have as much engine braking, but I just dropped into low gears (including 1) and go slow (or wife yells) and it worked fine.
On my old 5-speed Allison, T/H made a noticeable difference: holding upshifts, aggressive downshifts, locking torque converter sooner.  On this 10-speed, I can't sense when the torque converter locks or notice much shifting difference.  Even so, I put it in T/H on steep up/down hills in case it does make a difference.  On highways it does go between 7-10 but I assume that's ok.  I also assume "wearing out" will mean the valve body and Nextgen may be sometime in the future.
I was actually referring to the park brake engaging without the drivers knowledge when shifting into park when on a grade, I honestly don't know if the HD trucks also do that or not but a friend that has a 2023 half ton with the 6.2 ( his transmission valve body is now claimed to be crap and his trucks resting at the dealership ) his truck will apply the park brake even in a sloped parking lot and sometimes randomly in his driveway pad. The first time it happened he didn't know what to do and had no idea the park brake was on and the truck would not let him move out of park position until he disengaged the park brake by pressing the button was my understanding. His would have the true center console electronic shift controller.
What you had happen and I've not experienced that yet ... is the hill start assist and from reading GM generic info they talk about it coming into play on a 5 percent grade or steeper in both uphill or downhill. I don't know if that means reversing up a hill and stopping and then going again, I didn't find a detailed explanation but it made a comment about a 1.5 second hold delay and its only my assumption that it would then release the brakes. On a hill sometime where its safe you could try it and let go of the brake and not touch the accelerator and see if the brakes release on their own and then start rolling backwards. Stuff like this was made for standard transmissions, now apparently they think we need it on an automatic. I haven't found the wipe your butt feature yet but its got to be in there somewhere LOL.
My truck because of the Z71 package has what they call hill decent control and it would operate at slower speeds and is driver engaged and of course it would be dragging the brakes down a hill when engaged, its more of an off road function idea but says it could be used up to 40 mph and can see someone mis using that on the highway and smoke their brakes down a long mountain grade ... gimmicks gimmicks.
Yes so your truck has the spring setup I thought it would have. I had falsely thought that my 1 ton would have the very same main spring pack as the 3/4 but with the added upper overload but no its slightly different. From what I can tell and it was someone on this forum who mentioned that , the 1 ton single wheel trucks lower overload spring is shorter than in the pack of the 3/4 truck, why is a good question but for some reason they did that. I think the 1 ton version may cause the overload to engage a little sooner but then being shorter would have a different reaction to the whole spring packs movement/flex after that, I'm sure some engineer figured out a reason why they needed to create the parts differences. It still blows me away that your truck isn't rocking around to the side, from highway curves to side winds ... and maybe you haven't been in as harsh a side wind yet to know how it handles the extreme conditions.
With 10 gears the feel of a shift from one gear to the next just flows and your right that I have no idea either when or if the torque converter is unlocking, its all so seamless. Keep in mind as well that as one is more aggressive on the throttle which you would be with a load or accelerating empty for that matter, the computer of these trucks is pulling the power out as it shifts and that is really noticeable if one starts out from a dead stop and floors it and keeps it to the floor ( like doing a quarter mile drag run ) as there are those dead spot delays as it pulls power just before the shift as the computers talk to each other. That makes for way less stress and wear on transmission clutch packs but crappy quarter mile times with so many shifts. As to using the manual mode to lock out certain top gears, that has been mentioned on this forum when pulling a heavier trailer due to the amount of shifting as it can only use those top gears when going down a hill. Your camper setup may be different though and it can make enough use of the upper gears but for the fun of it sometime you could do a leg of a trip using the manual mode to see what you think of driving it that way instead.
Let me guess, your hearing in your right ear is not as good as your left but as well it has more selective hearing LOL ( the wife comment ).  At least you know to shift down on hills and are not afraid to use 1st gear as per that very steep highway grade in California. There are a lot of flat landers out there that have never in their life shifted their vehicle down to descend a grade, they drag their brakes down the whole way and then wonder why they just about died or are still oblivious to the fact that their rotors are glowing red hot and that they were trailing smoke.
Do you happen to know what your front axle maximum weight happens to be on your sticker as well as payload weight and weight of the truck out of the factory. Being that yours is a work truck it would have some different ratings on it, would depend on which tires it came with also for its max gvw. I just know my truck for what it is and being a 1 ton isn't as impressive as one might think for payload capacity due to options that weigh it down, its not a light truck for what is there and only being a gas.
2024 2500HD 6.6L Gas WT Dbl Cab 4x4 long bed
GVWR:     10500 lbs
GCWR:     24500
CURB WT:   7173
MAX PAYLD: 3327
GAWR FRT:  5200
GAWR RR:   6390
This is with the LT265/70R17E all-terrain tire option.
Oh, just noticed you're in Canada!!
                        LBS.     KG.
GVWR:     10500   4763
GCWR:     24500  11113
CURB WT:   7173   3254
MAX PAYLD: 3327   1509
GAWR FRT:  5200   2359
GAWR RR:   6390   2898
Add "automatic brake dragging on downhills" to my list of things I would hate.  A sure way to overheat them and then not have them when you need them.  (Bragging) When I sold my 2004.5 it had 180k miles and original brakes with a lot left on the pads (well, at least fronts because I never looked at backs); just bled new brake fluid every 5 years or so.
I have hit strong crosswinds and had to slow down a lot, but it's so much better than my old truck maybe I'm just used to it.
                        LBS.     KG.
GVWR:     10500   4763
GCWR:     24500  11113
CURB WT:   7173   3254
GAWR FRT:  5200   2359
GAWR RR:   6390   2898
LOL, I'm old or at least feel old so I don't pay any attention to KG unless I am forced to such as weight tickets for grain or the highway tractor axle weights since the scales are only in KG up here and so forth and then I am taking my metric conversion calculator and converting various figures to Imperial if needed to better relate to the numbers. I was part way through school when they started forcing the metric system on us and my dad was not impressed with having metric forced on him. All it did was force us to buy tools to work on standard and metric fasteners and pay to have all speed signs changed in Canada etc. I know, lots of the world is on the metric system but we didn't live there, we lived here and beside the United States and also its political as per eastern Canada dictating the rest of the country. Dad was born in Oregon by the way, his mom in Nebraska and dad moved to Arizona ( spent summers in Oregon or Washington state ) after he retired from the farm and was back in a land he could understand.
2025 3500HD 6.6L Gas HC crew cab 4x4 short bed
                            LBS.
GVWR:               11550
GCWR:               26000
CURB WT:           7687
MAX PAYLD:       3863
GAWR FRT:         4800
GAWR RR:           7250
The standard tires and wheels that come on the High Country are the 275/65R20 all terrain.
The fact that its a 1 ton would have very little to do with the added weight, it would be the upper leaf springs and the pads on the side of the frame as the rest of the truck is almost identical from what I understand, perhaps a slight difference in some cross member but all other components are the same that I am aware of. Its the options that add the weight, two alternator with two battery option, the larger tires over a WT, so called leather seats ( I did not get nor want the sunroof and it adds weight to a truck as well ), the spray in bed liner with the fifth wheel prep, the running boards that came standard from the factory on a HC, oh and a block heater as its Canada after all "EH" So my truck being shorter in wheel base and yet packing an added 500 pounds, that goes to show how much would be taken off of payload for a truck like yours that was an optioned out HC in a 3/4 ton although with the larger tires I think they add a few pounds onto the GVW.
Automatic brake activation ( if the driver activated it ) we both shake our head at that and indeed it could be activated at a slower highway speed and what a bad or maybe ones last mistake one would make as it would not be smart enough to know that the brakes are heating up, but its a sales gimmick for those that don't grasp the concept. I only wish brakes would last like you had on your prior truck and its hard to say what the condition was of the rear pads. What happens here when a vehicle is driven during the winter is major rust if it sits for any period of time not being used on the brake rotors and rust getting into the rotor material and literally rust jacking and flaking off the side of the rotor rendering it trash. The sand spread pouring off the front tires flying to the rear brakes drowning the pads/rotors in a constant supply of abrasive sand wearing out the brakes even when not being applied, never mind that I live on a gravel road so dust/sand flying into the brakes during the summer. Oh and good luck turning out the bleed screws to bleed the brakes as they will be siezed and have to toss the calipers along with the rotors when doing a brake job, doing brake jobs is very expensive when all components have to be replaced as you can well imagine. If a vehicle is only driven in the summer on paved roads up here and never ever sees salt or gravel roads, its an entirely different deal and the vehicle isn't rusting away either. That is why my dad never wanted to see a winter road ever in his life again after he retired as he knew the unreal costly damage it does to anything put on these roads.
So with all you did with the old truck with sway bars, you find the new truck is actually better as it sits stock ?. But if you ever felt you wanted to do some upgrading, Hellwig does make a few rear sway bar options as well as a front one and roadmaster makes the huge 1 1/2 size for the rear of the GM but I'd first start with the rear since there is nothing back there and the factory front one is pretty beefy, or the timbren idea in the rear. Maybe your wife won't scream as much in cross winds and as such your drive will be less stressful LOL. I've never driven my brothers camper truck since he put those sway bars on it, I've only driven it once and I wasn't dealing with too much wind so it seemed fine but certainly I could tell it was one heavy/top heavy unit and had to take things cool.
As I was writing down the info off my truck I got thinking about your truck as it has the slightly heavier front torsion bars although it would not have the camper torsion bars either. I wonder in your glove box if it has a sticker like mine that says not suitable for a slide in camper or some such wording. Think of all the trucks made through the years, not as capable as these trucks and there was no such thing as can't haul a camper theme with a 3/4 or 1 ton.
Mine has no problem hauling the truck camper i have in 10th gear. It goes there on its own after settling in. Anything more than a light head wind it wont do 10. Thats speeds 55-72mph.  Nice and flat hear.
        Just because it goes and sits in 10, dont mean it gets empty mpg's like in 10.
        I dont ever use tow haul, i never have in any pickup.
When Jake was talking about his camper and using 10th or should say in drive mode and it used whatever gear it could pull it in, it donned on me that a truck like his even with the optional larger 17 inch tire option is geared down some compared to the size a truck like mine came with. Which brings me to your truck, what size tires did your truck come with ?. Also your camper isn't as high as some although its certainly pushing more wind than a pop up by a fair margin and I think your camper is slightly narrower than the bemoth sized ones. Do you know what your total weight is of your rig when typically loaded up ready for the road and in your case that means the possibility of all that extra fuel although not sure if your always carrying a full load of fuel or fill it when the price or situation calls for it but don't always carry around a full spare tank. Weight and wind resistance, two things that are a killer for fuel mileage and being able to putter along down the highway easy in top gear.
Speaking of final gearing at the ground, lately I was figuring out on paper as to what the difference was in top gear at a certain speed between the neighbours duramax dually with the 3.42 vs my truck with the 3.73. Because my tires are quite a bit larger in diameter vs a smaller diameter dually tire, my engine runs hardly any faster in a given gear than his does even though there is a certain amount of a gap in the diff ratios. Also the smaller the tire the lower the overall height and less air flowing under the vehicle, it all makes a difference.
For my 2500HD, it says max payload is 3327 lbs.  The sticker in the glove box says the maximum slide-in camper is 2427 lbs.  The owner's manual says to use 150 lbs per seat which for 6 seats is 900 lbs, which just happens to be 3327 - 2427 = 900, so that's why it says 2427 lbs for the slide-in camper.  A generous estimate of our weight (with clothes and shoes) is 350 lbs, so I guess my CWR ("Cargo Weight Rating") is actually just under 3000 lbs.  But this is all pretty ridiculous because there are so many other things affecting weight (food, drinks, tools, bike rack, bikes, etc.).  At least mine says a slide-in camper is suitable!
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
