Has anyone used Johnson Lifters instead of the GM/Delphi stock/LS7 lifters? From what I can tell, I've not seen anything bad about them and they seem to be preferred by a lot of people in other forums. I've seen it mentioned here a few times to go with Johnson lifters and not the LS7 lifters, but haven't seen anyone mention some of the specifics I'm looking for:
  • quiet/no ticking (quieter than stock GM lifters?)
  • long lasting
  • what size push rod did you need / any other changes other than the cam
TSP has a DOD/AFM DIY removal kit here, but it doesn't seem to offer any drop in push rods for the lifters. In fact, it seems they are out of Johnson lifters, but I've seem them available on other sites. https://www.texas-speed.com/p-5443-build-your-own-tsp-gen-5-lt1-lt4-l83l84-l86-l87-dod-delete-kit.aspx
  • long lasting
You might want to contact GPI, they have a great reputation building LS/LT engines. The Johnson lifters are pricey.
https://gwatneyperformance.com/camshaft-valvetrain/lifters/
Iirc not 100% sure,  but I remember the Johnson lifters being prime for engines with low vacuum. I think that was what everyone was choosing them for. Small cams did not need them as much. Been a decade since I built an engine, but that's what I remember.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
