Rear trailer camera has been working great for 1 1/2 years. on last two trips, started acting flakey. It will go on and off constantly almost looking like it was a bad connection that was happening when I would go over bumps. Now it doesn't work at all
Did some tests with my wife in the truck and me wiggling the connection on the bumper as well as the wire going into the camera but could not get the camera to turn back on.
I have also cleaned the connectors with contact cleaner with no success.
Anybody else have issues with their rear trailer camera like I am having? Was it the camera or the truck?
I would really like to find someone with a similar truck to hook up to my trailer but finding one is going to be tough. Not sure if I should take the camera off the trailer and bring it to the dealer or just bring the truck in. My dealer has no room to bring both in unless I find a different dealer with more room.
Our team would be happy to help you find other dealerships in your area, Bruce. If you're interested, please reach out to us at [email protected] with your full VIN, full name, zip code, and mileage and we can get started. By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement: https://www.gm.com/privacy-statement.
These trucks use "hacked up" Pulse Width Modulated DC going back to the trailer connection for the trailer lights. The camera uses the same PWM DC voltage to power your camera.
You can purchase a PWM filter in between your camera and your camera connection. You can get these filters on Amazon for next to nothing.
Also, make sure your camera monitor is not set to cycle between camera's. It needs to be set not to cycle, i.e stay on the same camera without trying to cycle.
Edited by viking59
This makes zero sense. Why would I put PWM filters on a factory trailer camera?
Also, there is no camera cycling.
Edited by bruceb58
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
