Hey everyone, we just wrapped up a week testing the new Traverse Z71 out here in the New Hampshire slop. I really wanted to see if Chevy actually built a legit, winter-capable SUV this time around, or if they just slapped some all-terrain tires on a minivan.
We put the new twin-clutch AWD through its paces on deeply rutted dirt roads, tested out the cabin tech on 10-degree mornings, and got some hard, real-world MPG numbers on the new 2.5L turbo to compare against the old 3.6L V6. You can check out my full, honest breakdown on the homepage here: https://www.gm-trucks.com/tested-chevy-traverse-z71-mud-season-review/
For those of you who already have a new Traverse in the driveway—are you seeing the same fuel economy numbers I did? Let's discuss it below!
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
