I drive a 2021 Chevy 2500hd. Having an issue with trailer lights staying on. Is there a trailer light control module on my truck? The dealership is telling me no. But everything else I see online it says there is one. Does anyone know which module controls the trailer lights on this truck? Vin 1GB1YLE73MF171983
What do you mean by "staying on"?  They are fully on, after turning off the truck and the trucks lights are off?  All the time, even the truck is running and the truck's lights are off? Or something else?
Edited by davester
11 hours ago, chris21 said:
Check the ground on the trailer
Ground is good. It does it on ever trailer I hook to. With the truck shut off the passenger side running lights and tail lights stay on no matter if the truck running or not. Getting 12v at truck plug 100% of the time .
You do NOT because you have the WT trim and ZW9 box delete.
All trailer lighting is handled via the relays and fuses in the under hood fuse box.  Fuses 41, 55, 63, 73 and 81.
Do you have any sort of aftermarket box, dump, body of some sort installed on this?
Edited by newdude
4 hours ago, Hardhands85 said:
...the passenger side running lights and tail lights stay on no matter if the truck running or not. Getting 12v at truck plug 100% of the time.
There is not a specific running/tail light for the passenger side.
The only light specific to a side is turn signal (technically this includes brake lights too).
When you say that you are getting 12v at the truck plug 100% of the time, I'm assuming that you are probing the pin labeled "Right Turn".
The only circuit that carries 12v to the trailer is the auxiliary power circuit used to charge trailer 'house' batteries or break away back-up batteries. It sounds like this circuit is somehow powering the right turn pin - whether by intention (maybe a previous owner changed the truck for some reason?) or by mistake.
Long story truck I would first confirm that all circuits going to the trailer plug are in the correct spot. gmupfitter.org will have wiring diagram and colors for the truck you can use to confirm.
 Sounds like connector on the truck is not wired correctly
Edited by chris21
