Hello, I’m new to the forum and didn’t seem to find anything along the lines of what my issue seems to be on my 2012 Chevy Silverado 5.3…
My oil pressure sensor went bad and I drove it for like a month before replacing it (broke my ankle so I couldn’t exactly get to it) and during that time, it drove fairly decent. After replacing the sensor, it drove amazing until I noticed a big oil puddle under my truck (sensor came loose somehow) so I tightened it and my oil pressure for the first 10 minutes of driving, sits at or above 40psi but the longer I drive, the lower it drops and sits around 20psi but ever since replacing the sensor I’ve had nothing but misc problems that come and go, for example; I’ve been getting a code for a Cylinder 5 Fuel Injector Open circuit and a code for a bad ignition coil on cylinder one. Both problems were addressed and the engine still runs rough, especially when sitting at lights for extended periods of time and then it’ll stop and then randomly come and go. I’ve had my Traction Control and Stabilitrak turn on and off leading to the truck running poorly, poor shifting, poor acceleration and a “stop and go” type feeling when accelerating. I have tried charging my battery, disconnecting my battery for 30 minutes and then connecting again to reset the computer but the same issues persists. Ive had flashing check engine light, consistent check engine light that comes and goes randomly as well. My radiator fan is running on high all the time and it feels like my heat is on even when it’s not. I have been led down the road to believe that either my ecm/pcm is bad or alternator is bad but not sure if I’m on the right track and don’t want to throw money in unnecessary places.
I’ve been struggling to figure out the true culprit of my issue and was wondering if there’s anyone who could help me start figuring this out. Thanks for any and all help in advance,
Austin
current codes? Fans running all the time is usually a bad thermostat
Did you remove/replace or clean the screen under the oil pressure sensor? When they get plugged they cause all kinds of odd oil pressure issues. Not sure the other issues are related but the screen may explain your oil pressue issues.
Edited by Jay P
Need to carefully examine the wiring on bank 1, drivers side, you might have damaged something, knocked something loose, etc. Specifically, look at/follow wires for the cylinder 1 coil and cylinder 5 fuel injector.
Maybe the harness got pinched or crushed during the oil pressure sensor replacement, or by the tool. Its tricky to get back there and see what you're doing.
Possible rodent damage too.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
