Has anyone found a Cat Back Exhaust that does not drone when towing?
Edited by GAMark
I was fortunate enough for many years to know a custom exhaust bender. When cross over exhaust became a thing is when drone showed up. Uneven exhaust sounds the best in my opinion. They have all kinds of tricks now to eliminate drone. I saw a demonstration where max HP was achieved with single exhaust. Most modern factory exhaust flows to achieve max rated horsepower without intake modifications or additional tuning. The last exhaust I did I simply changed the muffler leaving the resonator to increase sound without drone. My last performance truck I did true duals without the cross over, loud no drone. If you go with most any modern cat back. It will sing while pulling. There’s loud than there’s drone. One sounds good the other doesn’t. If you have access to an exhaust shop I’d start with a different muffler, just the muffler. You could spend a fortune to eliminate drone.
My understanding is a properly setup "J pipe" will eliminate the resonate'n but, I don't understand the math to it.
Also more accurately known as a Helmholtz resonator.
Edited by OS RR
I have a dynomax cat-back on my truck, been on it for probably 7 years now. You can barely hear it on the freeway and when I tow my 20ft car trailer. This is on a 2016 Silverado though, newer trucks to me are quieter on the inside compared to mine.
I believe the J-pipe causes a 180 degree phase shift in the frequency that causes drone. Doing so cancels out the sound.
I installed a Borla S Type on my 24.  I love it and have no drone, at highway speeds cruising you can barely hear it.
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
