Does our 4-wheel drive system need to be exercised? If it is not used a lot?
Absolutely!  These forums are legion with posts of people complaining that their truck wouldn't go into 4WD when they needed it to.  Most of them hadn't used it ever or in years.
I try to run mine through the paces every month or so and drive it a few miles on a dirt trail near the house a couple times a year if not already off-roading.
It is always a good idea to exercise it at least every few months to make sure the actuators don’t get stuck. It is also a good idea to actually drive it for at least a few hundred feet when you do that so seals experience motion and oil movement.  Off pavement or snow/ice is best for this, but driving wet pavement in a straight line for a  short distance will work if you don’t have other options. I have  forgotten and gone as long as six months between exercising it on my 2021 and it has always shifted promptly.  I usually just use my straight 300 foot gravel driveway.
It may or may not help with keeping things working, but even if it doesn't help, testing that it does work when you don't need it, makes it more likely it will work when you do need it, and/or you can fix the problem so it works when needed.
Definitely its a habit to get into, every so often go through the motions of both high range and low range and allow it to rotate over for some distance to coat all the surfaces with oil that otherwise may not receive any otherwise and like was said to coat and work the seals etc. I too am doing it on a non busy gravel road during the summer or come winter again the snow covered gravel road simply because its not busy and can mess around putting it into four low. Of course I am using four wheel high range quite often for portions of each drive all winter which would be different then one who lives in an area where unless going off roading the four wheel drive almost never gets used.
I do on occasion. Not super often but maybe once every 3-4mo I’ll just put it in high on a straight section of road for a few miles.
I live in Vermont, 4WD gets used quite frequently during the year. 😀
I doubt two wheel drive pickups are a hot seller off the new vehicle lot in your area !, I highly doubt any of the dealers around here have brought in one two wheel drive pickup for many years as that four wheel drive system isn't along for the ride here or I can well imagine in Vermont during the winter. Of course some of our more poorly maintained gravel roads are so bad that during the summer if it rains a person could get stuck right in the middle of a gravel road in two wheel drive LOL.
I have owned many GM 4wd vehicles dating back to the 1980's and driven all the big 3 brands at work (GPS Survey team).  Granted I live in upper Michigan where its winter (300+ inches of snowfall this past winter) from Nov-April (+-) but other than having it in AUTO 4wd then, I never excise it when I don't need it.  Never an 4wd issue ever.  Btw, according to a fiend who is GM tech, 99% of 4wd issues he encounters are attributed to oversize tires.
Now if you are one who has a 4wd just for a status symbol (many do) and really never use it then it might be a good idea to do that occasionally just to make sure you know how to use it. LOL.
Edited by Z45
Same no dirt roads, so I put it in 4hi on a straight stretch of road, set the cruise to 45, and go.
  • 3 weeks later...
Cool to see another Vermonter!
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
