I think the 2027 trucks look great, although I will be keeping my 2025 since it will paid off in January. Now, in the original post it was stated that the 2.7 finally gets the 10 speed. I'm not sure that's a good thing. So far it seems like the revised 8 speed from 2024 and on is a better transmission than the 10 speed. I guess time will tell.
I'm underwhelmed.
Too much Hummer parts bin salvaging, mirrors and steering wheel.
"More expressive interior color schemes", nowhere to be seen. Same old Jet Black everything with different seat covers trim bits and maybe door accents.
Lots of dumping every other idea in the truck world into this: work surface console lid, pano sunroof, passenger screen. Not saying they are bad, pretty obvious GM was late to the game now adding it.
The weird marker lights over the bumper at the front of the bumper.
Mixed feelings on the fender flares.
I've touched my headlight switch twice in the last 5 years.
Its not bad, but nothing game changing. No massive leap frog over Ram or Ford, its competitive.
17 hours ago, tjonesdfw said:
Same… have been used to reaching in the door or window and using the light switch for years.  On the glass center screen makes zero sense ergonomically but I can only assume some young engineer or accountant justified it by saying they’re automatic and no one uses the switch.
Not to mention when you want to automatically turn off the lights now you got a blaring screen blinding you.
We still haven't seen the GMC's. I expect the Chevys to more orr less match the Fords, but with no all aluminum body and simple SBC, be significantly more affordable. I'm hoping GMC offers the 6.7 engine and lays it all out on the line. My main question? More premium GMC's already use composite leads out back. Does Chevy get any? What other frame/suspension changes?
21 minutes ago, Jake87 said:
Does Chevy get any?
Is the carbon pro bed still a thing? I figured it was one of those things that quietly disappeared from low take rate.
I thought Chevrolet tried adding it too...
Minimal.
Despite all the 'all new' versions since GMT-800, lots of parts still swap from generation to generation.
I've seen a bunch of GMT-800s with a K2 rear bumper on them.
I'm just amazed there's any interest at all after their track record the past 19 model years.
How many years did people get screwed by AFM? Then the 6.2 debacle ... and the variation from Ford's exact 10-speed that works fine, but GM had to take it and screw it up as usual causing yet ANOTHER failure mode ... and the list goes on!
From my perspective this sounds like a company with contempt for its customers. I vote with my wallet.
  • Haha 2
I was a Chevy guy for years, then switched to GMC because I liked the looks better.  I'm actually thinking I like the Chevy looks better than GMC for the first time in a lot of years.
One thing I know for certain, the new GMC dash is hideous!  Chevy wins this one!
We have now!  2027 GMC Sierra  Early look, but I'm a GMC guy and so far I think I like the looks of the Chevy better.
On 6/16/2026 at 12:18 PM, GMTruckGuy74 said:
If I may, I'd like to post my prediction of the trim levels for the 2027 GMC Sierra, based on what was released/introduced today about the Chevy Silverado.
Using the "Professional Grade" wording already in use by GMC, here are the eight (8) trims I believe the Sierra will offer (comparable Chevy trim in parenthesis):
  • Sierra Pro (Work Truck/WT)
  • Elevation (Custom)
  • Elevation Premium -or- Ultimate (Silverado)
  • AT4 (Custom Trail Boss)
  • AT4 Premium -or- Ultimate (Trail Boss)
  • AT4X (ZR2)
  • Denali (High Country)
  • Denali Ultimate (N/A)
If GMC would rather simplify the trim levels, then I predict six (6) with package upgrades in parenthesis:
  • Sierra Pro (with a Graphite package upgrade option)
  • Elevation (with a Premium -or- Ultimate package upgrade)
  • AT4 (with a Premium -or- Ultimate package upgrade)
  • AT4X (with AEV and Ultimate packages upgrade)
  • Denali
  • Denali Ultimate
Let's see if I'm close.
You nailed it with 6 trims.
On 6/18/2026 at 8:13 AM, Flynlow said:
I really like the look of the new truck.  I have a 2024 Sierra now and will keep it, but I'm jealous that the shifter is back where it should be... on the column!  The goofy shifter in the console is one of the few things I hate about my truck.
I never understood the hate for the column shifter. The console shifter just gets in the way, takes up prime cargo space and in my wife's Jeep, the dog constantly bumps the console shifter into neutral!
Best choice ever to just make it a column shifter across the lineup and be done with it.
(Bonus: Makes swapping from a 5 seater to a six seater far easier)
I actually prefer the GMC interior. Gives off mid-century modern vibes.
Have to go with the Chevy dash this time. GMC in my fav in the current trucks but the 2027 GMC has a hideous dash.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
