What are everyone's opinions on Rain-X? I used it for the first time on my truck a couple weeks ago, and while the water repelling properties are very nice, the effort that goes into keeping the windows clean seems to have really increased. I am out trying to windex the windows right now, and the rain-x seems to be reacting with it in some way. when i try to wipe the windex off, the windows have a nasty film on top of them still. I definitley dont like the fact that the windows look smudgy after spending over an hour cleaning them. I dont think I will be re-applying rain-x anytime soon. How long does that stuff take to dissappear anyway?
Did you make sure after you applied Rain X to wipe off the haze with a clean cloth? You are better off using Rain X windshield washer fluid. I having been using this for the last couple of years and found that my windshield has less hazing and it keeps your windshield seasoned. Plus it is more convenient because everytime you spray your windshield your are reapplying it.
The only thing I don't like about RainX is the application.
Takes a LOT of elbow grease to get rid of that haze on the first application, after that....It's great.
Seemed to leave my windshield greasy or something! I havent used anything for a long time and when I did I would only do the sides and the back, because I didnt like that greasy look when I did use my wipers.
I've been using RainX for 14 years now and had the haze happen to me a couple of times. I can't really explain why, but it's a PITA when it does. Now what I think caused it for me was the weather when I applied it. If it's kinda cold out and/or it's very humid, this happens. At least for me. It's the best I can come up with.
HOWEVER, 95% of the time it comes off very easily. I have great results if I do it on a warm sunny day in the sun. I will apply 1 coat and the another on one side of the windshield. Then do the same for the other. I let it dry for 10-15 minutes then take a LIGHTLY moistened cloth and wipe it off. Then I take a dry, soft cloth and buff it out the rest of the way. Once the moisture is gone it just comes out to a shiny, clear sheen on the winshield. As stated before, I have also been using the windshield washer fluid, not for very long, though, and I really like it. Works just like it was applied by hand.
But, I've been using this stuff for so long because I absolutely love it. I would not be happy at all without after seeing the incredible difference it makes. It's one of the VERY few items that I've seen that actually works like it says it does on TV. Great stuff!!
if your reason for water repelling is increased visiblity, then just get a set or PIAA silicon wiper blades.
Best investment i have ever made for my truck :thumbs:
:wtf:
:werd:
I will never own another pair of non-silicon wipers again, they are SOOOOOOOOOOOOOO much better, and ultimatley more cost effective too it's just not even funny.
Deltron....If you dont like the hazy view from Rain X - I have removed it with Lestoil. I mixed a little in some warm water...and Wash your Windshield with it. Be carefull not to get it on your paint. This will remove all the rainx from your windshield.
I just started using Rain X again.....after not using it for a few years....the only thing that I have noticed is that you have to keep up with the aplication. Almost have to do it every couple of weeks or your vision will be a little hazy on misty days.
.02
D
When you use Rain X, which i have for as long as It has been out, the best way to clean it is to use 409. After a time the window gets a coatof what seams to be road oil. The 409 take it right off and the Rain X stays.
I am a firm believer in RAINX. When you clean your windows (outside) use either
plain water or make a solution of the solution out of the windshield washer addtitive,then use this on the outside. This will no remove the RAINX protection and will enhance the application. I only recoat my only about 2 times a year.
BTW - I do all outside glass, front, sides and back.
I love the Rain-X washer fluid.
Works good.
I don't think it could POSSIBLY be easier to "apply", and I can (and do) do it while comfortably seated.
I've used RAIN-X and the RAIN-X washer fliud for years,I became a huge beleiver after I drove thru tropical storm force rain without having to put my wipers on at all...I dont even use windex on the treated glass,I just use a clean soft towel(cotton) Also helps to wipe the wiper blades clean w/alcohol when gime builds up on them.
I like rainX have never had any problems has always worked out great
Matt
