Headlight Change
On a 99 GMC Suburban, How do I access the bulbs to change them? :P Looking under the hood, the only one I can see the connection on is the left low beam. The only screws I see are on the directional assembly below the headlights.
Ed
I got the answer to this question on another forum. Anyone that needs to know, you use a 4mm socket to pull out two rods that sick up from the top of the headlight assembly. Pull out the assembly (after unhooking the wires :P )and you are all set.
