went exploring....
well, first thing i noticed when i got on my creeper and rolled under the Sierra is that there is alot less ground clearance than my 87 K20. I couldnt roll from the nose to the tail like i can with the older truck. What a difference 16 years is between trucks..
I was looking for a location to put a tranny cooler (4.8L) and didnt see any obvious spots. There is a skid plate (more like a plastic cover for all the steering components) that i thought about tucking up in there. Best bed is to try and get one up in front of the rad.
Saw the transfer case and its special note to techs calling out that it is made of magnesium. cool.
How do i know if the torsion bars have been adjusted? the truck rides good and is flat (nose isnt down more than the front).
The fuel pump is mounted on the frame and not in the tank, thats nice.
Looks pretty solid under there. Alot cleaner for sure than my old one..lol
I didnt see the oil filter, but didnt look too hard for it.
Plugs look easy enough to change out. Only 54K miles on it so i ll wait a bit longer. Saw that the gap is .060". pretty high isnt it?
just some thoughts on things i noticed while crawling under there.
The tranny is a 4spd. Is this still the 4L60E?
any other things i should know about that anyone can think of?
thanks.
later all.
Lee
thanks.
later all.
Lee
Tranny cooler is best in front of radiator and mount it on drivers side if it is open as it will have least impact of engine cooling there. Make sure you route oil through radiator cooler first then aux cooler. Yes they are lower and the cross member under tranny/xfer case does not help matter either. At least in the classics (88 till 99) that cross member was inside of frame rails.
is any cooler better than another?
or should i just get one from Summit?  B&M coolers.
Lee
Hayden will work too. To me brand does not mattter as much as the size for application and its presence. Something in the neighborhood of 6 to 7 inches wide by 12" or so long will do nicely. Advanced Auto sells a brand that I have used for over 25 years and with good results too. (never lost a tranny with one)
Stacked plate coolers work a little better than tube/fin coolers. Less pressure drop, more surface area, etc...
DEWFPO
it was great! i was poking here..sticking my finger there and getting all gooey and wet. rubbing up against....ahh...ummm...well...nevermind..
the truck looks in great shape underneath. not as HD as the K20 but alot newer for sure.
later.
Lee
Thanks for taking us there, Lee. Ever thought of being a poet?
Well done!
Yeah, that's the venerable 4L60E.
DEWFPO
They also restrict airflow through the core and rest of cooling system a lot more too and the airflow needs to get to rest of system too. I prefer the tube and fin for this reason and using a infered temp sensor I get a 25 to 30 degree drop across my fin cooler at a idle with engine is warm and clutch fan is engaged and my cooler is about 6 x 13 and a tube and fine type. This is after it passes through tank cooler too.
didnt look like a fuel filter..saw three separate fuel lines coming from it. will take another closer look at it when i get some time again.
thanks all for the tranny cooler suggestions. i ll start looking thru some catalogs.
later.
Lee
I got my trans cooler from Summit, it's a PermaCool 17,000 GVW. I'm very happy with it...just had to paint it flat black prior to installation (it came bare aluminum)
    • I can relate. 3 years ago I did that on my Avalanche. I was sore for a week. The only maintenance I do myself now is drop and fill on the transmission on my Honda’s. It’s just too easy. My yard work with my walks in the morning will be enough now I passed 70. The contributing factor is the heat in Texas. You just have to pace yourself.
    • I am sorry if this was misleading. That was a document attached to our most recent work order number (Doc# 7105804) that summarized all the current updates. These programs were ‘redone’ in the past but these versions dated 4/1/2016 were the ones that actually made all of the problems disappear. These programs were relayed to the dealer from the technical services group at GM. Here is the exact wording on the last work order:   “Front view camera reprogramming with SPS. A new version of FCM software was released to the service dept. In addition to providing general robustness and stability enhancements, this update includes all enhancements from previous software version releases. SPS camera and calibrate camera. OLH to perform extended camera relearn procedure after camera calibration. Would not take with first GDS learn. Front camera SPS – BDYZ333157450 GDS2 – camera road calibration performed 2810835 Front view camera reprogramming with SPS LT 0.6 OLH – extended camera relearn procedure OLH LT 1.5”   I got the truck back on 4/8 – since that time it has been great no problems whatsoever. The lane keep assist, active cruise control and AEB all work very well around town and at highway speeds up to 80mph. During this time I had been away for a week and purposely let the battery sit without a batter tender. Even with the battery a bit lower there were no problems exhibited. I really think this one has it fixed after dealing with these issues over a couple of years. These new programs and relearn process when completed seem to make all the parts (and newer replacement parts) ‘talk’ to each other without any glitches. Hope this helps
    • I turned 72 today. My day began with a trip to the pharmacy to pickup meds for me and the dog and then a stop at my chiropractor before heading home. Once home I started the job of replacing the rear brake pads and one rotor on our 2018 Silverado which will probably end up taking me 3 days to finish, gotta pace myself you know. Sometimes I question myself on why I still do most of my own repairs but if I wasn't then it's more than likely I would be sitting in front of the TV all day. It seems like the list of things I need to do gets longer no matter what I accomplish. I'm not complaining but being retired was so much easier when I was 62.   Peace
    • google "bathub failure curve". Basically, any part of the vehicle can fail at any time.  It starts off as being more likely (early failure), then the failure rate goes down (but does not go to zero), then it goes up over time because it wears/ages out.
    • I went from every other day to about once in five since the rain abated. I'm not unhappy about that. Took most of the month for the ditches to dry enough to mow.
