manzanoj Posted May 17, 2005 Posted May 17, 2005 Do you guys wax your whole truck? Including the rocker panels and roof? I usually just wax the sides, the tail gate, and the hood.
J-rod Posted May 17, 2005 Posted May 17, 2005 Yeah, unfortunately I usually don't get around to it more than a few times a year so I wax the whole thing. And actually, I'm usually more careful to wax any of the upward facing surfaces (hood, roof, etc) than the sides since that's what takes the most direct sunlight and is more likely to have water standing on it. Guess the rocker panels would be another good place to keep a good coat of wax though.
carbuster Posted May 17, 2005 Posted May 17, 2005 Yeah I wax the entire thing most of the time, unless I'm just using a quick wax or detailing wax or so.
oldredhat6 Posted May 18, 2005 Posted May 18, 2005 I wax the whole thing and it takes awhile with the ARE topper. Did both trucks mine and wifes for mother's day. Takes about 3 hours each by hand. Thinking about a buffer.
3amigos Posted May 18, 2005 Posted May 18, 2005 i wax my entire truck when i wax it, it helps when u clean it the next time, sum places get hit by sun harder than other. and i dont wax mine very often. so when i do i get the whole thing
J-rod Posted May 18, 2005 Posted May 18, 2005 ... Takes about 3 hours each by hand. Thinking about a buffer. Highly recommend it! It cuts the job in half just using it to take the wax off (which is what I usually do ... put it on by hand, take it off with the buffer).
IDGBZ71 Posted May 19, 2005 Posted May 19, 2005 The whole truck a couple times a year, buffer does cut the time down. Use the buffer to apply it that way you work the wax into the poors and remove by hand/buffer. The roof is always a good idea to wax to help prevent oxidation/fading. Waxing the rockers wil help with cleaning and help prevent rusting. I'm very anal about my truck, being my 1st new vehicle and wasn't cheap.
asilverblazer Posted May 20, 2005 Posted May 20, 2005 How do you guys apply the wax when using a buffer? Do you put a blob on the truck and smear it around, or put some on the buffer and smear. Then do you keep smearing until it is gone or how thick and so on and so forth...
USA1Fan Posted May 20, 2005 Posted May 20, 2005 The whole thing here too. ('cept for between the bed and cab. Can't figure out how to get in there even for basic washing!) I follow the instructions that came with my polisher- apply a quarter sized amount of liquid wax (preferred over paste wax according to those same instructions) to the center of the pad, then work a 2' square area using crisscrossing patterns on the horizontal surfaces (hood, roof). For the sides it says the pattern isn't as important and to just go with the body panel. It still took a lot of manual hand waxing to avoid spreading it onto the flat black panels or into creases (like around moldings). Waxing took me around 2.5 hours. The whole cleanup (wash, clay bar, wash, dry, wax) actually took me probably closer to 6 or 7 hours. But it was my first time doing clay bar, and my first time waxing a truck. (The Trailblazer was about as bad though- getting to the top was a bitch.)
Elwood 2000 Posted May 20, 2005 Posted May 20, 2005 Unfortunately, I don't get to wax as often as I used to, but when I do, I even do the door jams, paint under the hood and inside the bed. I don't know how you guys get done so fast, for me to do mine to suit me, it takes almost 2 days!
rascal Posted May 21, 2005 Posted May 21, 2005 I got to wax mine. Firm believer it should be done once a year, well i'm on my 2nd summer and still havn't got it done. LOL. well I at least wash the truck once ever couple of months. I hadn't thought about useing a buffer, thank you all. wander if my neighbors got one?
carguru Posted May 22, 2005 Posted May 22, 2005 The entire truck, once every 3 months, double coat all the upper surfaces (hood and roof). Random orbital buffer is a must with a fleet. I put an x pattern on the buffer pad. Here are the results: Don'tcha just love black???
DEV1ST8R Posted June 14, 2005 Posted June 14, 2005 Liquid vs. paste wax. . .does it matter? They both seem to work equally well from my experience. It would make more sense though for the paste to adhere and protect better though.
