2007 SLE DIC Upgrade
does Driver Information Center 19159438
work on the 2009 silverado LT
Yes.
reason why i ask is parts department says upgrade not for lt model
As is posted throughout this thread over and over again, go out, remove the panel that is there now and look for the harness clipped to the back of the panel that is plugged into nothing. If that is there, this will work.
Parts guys don't always know WTF they are talking about.
Some do, most don't though.
  • Replies 663
hey thanks to Daddy for this!!!
I just got my 09 LT Z71 and was a bit bummed that it didn't have the DIC buttons......well it will soon!!!
Awesome! :lol:
Just ordered DIC from GM parts direct for my 09 LT1.
$88.09 shipped.
Just curious, have they shipped the part yet? I ordered one 2 weeks ago from GM Parts Direct and it still hasn't shipped and they said it was on back order. Thanks for the help!
$88.09 shipped.
No, it says "In Process" on the order status.
That is not the kind of news I wanted to hear. I hope they get some soon.
I had one on back order from gm parts direct for 2 weeks and cancelled it. They told me they didnt know when they would be able to get it. Maybe all of the people ordering it off here have caused unecessary demand for the part so no one can get it. Way to go everybody!! My dad is the body shop manager for a dealership, so i had him order it from the parts department for me.
GMPartsDirect.com is just a dealership parts department that ships. It's Flow Chevrolet in Winston Salem, NC. I'm not sure if your Dad can order a GM part any faster than they can but good luck! :thumbs: Hopefully you don't have to start the two weeks all over again. :dunno:
The parts manager at the dealership he works at said he could have it in a few days, didn't say anything about it being back-ordered. There is another local dealership that said they could have it pretty quick too. Maybe the demand isn't as high down here in Texas
$88.09 shipped.
Order Status changed from "In process" to "On order".
Ordered mine mid-April on a weekend and had it about 10 days later. FWIW, I also ordered the parts individually rather than as a package. I was OTD with shipping for about $63. Best way to go IMO!
I just placed my order for the two separate parts with GMPartshouse.com. $66 including shipping.
Will let you know when they arrive...and how the install goes.
I gave up on GM Parts Direct, and cancelled my back ordered part. Went to the local GMC dealer, and he had the part for me in 24 hours ready to go for $85. He said the part showed up in the system as back ordered, but he pulled it from a dealer in Dayton, OH.
I'd suggest giving your dealer a call if you can't get in online and ask'em for a discount (you might just get it).
Anyway, great mod, had it installed in about 10 minutes. I had a little trouble getting the connectors off the old panel and getting the left hand corner back in the dash (not much clearance), but finally got it. I'm mad at myself for scratching the edge of the new panel in a few places next to the instrument dials, but I guess I am the only one that will really notice (still I hate damaging something I just bought). :D
Thanks again daddy! :rolleyes:
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
