2007 SLE DIC Upgrade
Who did you order it from?
GM Parts Direct.
Part: 19159438
Category: All
Description: DIC Switch Package
Min.Qty: 1
Unit Price: $66.50
Quantity: 1
Ext.Price: $66.50
Core Charge: $0.00
SUB TOTAL: $66.50
SHIPPING: $12.95
TAX: $0.00
TOTAL WITH TAXES: $ 79.45
how did you get it for 66.50? maybe i'm missing something. :thumbs: is this what you ordered
http://www.gmpartsdirect.com/results.cfm?s...number=19159438
I did see the DIC priced at $66.50 and did not buy it then, I bought it last night for $72.90 plus $15.95 shipping!!!!
  • Replies 663
I bought mine from GMPartsDirect in two pieces:
Part: 15947841*
Category: All
Description: SWITCH
Min.Qty: 1
Unit Price: $15.09
Quantity: 1
Ext.Price: $15.09
Core Charge: $0.00
Part: 25783286*
Category: All
Description: PLATE
Min.Qty: 1
Unit Price: $31.01
Quantity: 1
Ext.Price: $31.01
Core Charge: $0.00
SUB TOTAL: $46.10
SHIPPING: $16.12
TAX: $0.00
TOTAL WITH TAXES: $ 62.22 * indicates special order item, which is a special order non-returnable part.
slow sierra, I agree with your plan. I figured it'd be on national backorder, but if they cancel that item, I thought I'd go to my local dealership and see what they wanted. If it's out of stock or too expensive there, I can try my hand at cutting it and then order again later if it looks like chit when I'm done.
It's all good; just the switch would be awesome at this point!
well cutting this thing is a major pain! needless to say, I will be ordering the whole assembly tonight lol. Live and learn I guess. It is nice to have though, 14.1 mpg since I bought the truck :thumbs:
Official update:
I ordered from GMPartsDirect on 7/23 and the plate was on national backorder (as I figured it would be). I instructed then to cancel that item and ship the rest of the order. The switch alone ($28.04 shipped) went out on the 27th and arrived on my doorstep on the 29th. Not too bad.
I waited until this morning when I knew I had all day and just cut my existing dash. It's gorgeous! Especially when I think about having saved $45 in the process. My TOTAL cost for the DIC upgrade is $28.04 in cash and about 2 or 2 1/2 hours to remove the dash, cut the opening, and reinstall everything.
TIPS FOR THOSE WANTING TO CUT THEIR EXISTING DASH:
Remove the dash piece, then remove all the other parts from it; the headlight switch and the air conditioning vent both.
You'll need a Dremel (with an onion shaped bit; round, coming to a point), a triangular file about 3/8" to a side and a flat file about 3/4" or 1" wide. The wider the better for a straight, smooth cut.
Take your time; you've got all day. If you don't have all day, wait until you do.
Cut from the back with a Dremel and cut an opening smaller than you think it should be. Then finish up with sharp files. I only used the Dremel on the initial cut, then put it up. When you cut plastic with a Dremel, remember that speed only melts the plastic. I used speed setting 2 for the best cut without loading up on melted plastic.
Take your time; you have all day.
Make all cuts with a sharp file from the front to the back. This leaves the fuzzies on the back and easily trimmed with a sharp exact-o knife.
Take your time and be VERY careful with the finish on the face. Keep the files away from it and don't lay it face down to file on it!
Try to cut the opening with a slight bevel that leaves the front smaller than the back. This makes final fitting around the switch much easier.
Cut slowly and test fit OFTEN!
The short sides are easy to keep square, but the long sides are trickier. To make a nice straight edge on them, begin with an opening smaller than you'll need and work to get it square with nice straight sides even though it's too small. Take your time squaring it up at this stage. Then (here's the best trick yet) working with one edge of the opening at a time, use your triangular file to cut small notches all along the edge to the depth that you think you should be cutting. Make the notches a uniform depth and start/ finish in the corners, dividing the edge up into several notches. Then, with your wide flat file, cut until all the notches are gone. This way, your cuts will remain smooth and the edges straight. Be careful in the corners that you're only cutting the edge you're working on and not cutting with the side of the file.
TAKE YOUR TIME; you've got all day.
On FINAL fitting, get the height (top and bottom) right first, and then gradually widen the hole until the switch fits in without rubbing. A slight gap all the way around is better than tight so the buttons don't bind.
All in all, an easy upgrade. Cutting the hole takes some time, but at 2 hours and $45, your time is worth $22.50 an hour, so go for it. If you flub up, there are a ton of members here who still have their old plates; you should be able to find another one cheap.
Daddy, YOU ROCK!
I got my DIC today from GMpartsdirect.com and installed it in about 10 minutes. I paid $88.09 shipped. Average mileage for the first 1,500 miles.....15.8
Hee hee hee; gotcha beat. 4500+/- miles and I'm averaging 21.1. Woo HOO! :dunno:
I got mine from GMPartsDirect on Friday. Mine was 14.9mpg since new....430 miles. :dunno: Mostly city.
Definitely worth the $79.
I also have a spare non-dic panel now if anyone wants to cut it up.
How did you manage 21.1? Do you drive all highway? That's better then my 00 WS6 A4.......and I think I am babying my truck to get to 15.8!!! JEZZZZZZ
My guess would be a lot of either highway or country roads where the speed limits are constant. On a recent 2 hour drive back from camping mine was averaging 23.5mpg. :( City driving though I'm more in the 15mpg range it seems since I got the DIC switches installed.
Since I've had the truck, I've driven to Columbia, SC three times (350 mi round trip). I drive 80 miles a day back and to from work, but I only drive 1-2 days a week and carpool the rest. All the rest has been combination driving with a lean toward city.
My trick is that I drive slow and don't push it at red lights. So what if the other guy beats me to the next red light? I've got him beat at the gas pump! Even on the interstate going to Columbia, when the speed limit is 70, I'm rarely even driving 60. Watch your gas mileage over 55 MPH. It really starts to drain.
Question, when did you order? I ordered my DIC WAYYY back on June 3. Still have not seen any sign of it, everytime I write gmpartsdirect they tell me the part is on national backorder.
I ordered mine (part # 19159438) Tuesday July 28th from gmpartsdirect.com, $88.09 with shipping... I just checked it. It shipped Friday and is set for delivery on Tuesday Aug 4th.
I ordered it Friday July 24th and got it on Saturday August 1st.
I can't drive 60 on the highway......more like 80, guess I'll never get 20 mpg. Oh well!
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
