I Raced For The First Time Yesterday
VR021302
I raced a Hemi yesterday on the way home from work. I beat him and he let off, but I didn't. I did, however, find my governor. I didnt know that it is set at 95 mph. I'm not proud of the fact that I raced on a street, but I know the street, its straight, minimal traffic and 3 lanes wide each way. I am not happy that I can only hit 95, looks like my tune will be coming sooner that I anticipated.
just make sure your truck is stable past that mph. some say the govenor is for the tires. my truck is stable all way up till 150 a buddys truck was dancing around 120.
congrats on win
congrats! :nonod: , looking forward to your next race :D:lol:
Actually I am, but I'm gonna keep it to the track. After my tune though.
Whew! Good thing there weren't any cops around...otherwise it would've been a very expensive win. Be careful...
:nonod:
Oh yeah, I have a radar jammer/detector. Plus I really know that street, I drive it at least 4 times a day. But I won't be doing it again, that's for sure.
Sometimes the winner on the street is the guy foolish enough to go that fast, not always a measure of which vehicle is quicker. If you reran it at a track, I think the hemi would surprise you.
:nonod:
Also depends on how good the driver is. If the driver sucks, then having a big powerful vehicle isn't going to help much.
congrats on win
Yea, my Yuk XL begins getting a little loose too around 155 to 160. :dunno:
congrats on win
DAMN!!!!!!!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
