2011 Gmt-900 Truck Info
GMC
http://eogld.ecomm.gm.com/NASApp/domestic/...ge=&butID=1
CHEVY
http://eogld.ecomm.gm.com/NASApp/domestic/...0421&type=0
NEW for 2011 Sierra
Deletions
Exterior color (58U) Carbon Black Metallic
New Features
Exterior color (GGU) Gray Green Metallic
New for 2011 CHEVY
Deletions
Exterior color (58U) Black Granite Metallic
New Features
Exterior color (GGU) Steel Green Metallic
Do they have any pics of this new color?
It was released on the '10 Colorado's & Canyon's first. Sort of a light olive. Great truck color.
the black granite is much nicer
Agreed. They shouldn't have killed it. I'm not really a fan of that "new" color if that's what it is going to look like :D
well why the hell cant they just keep both? that greens not bad...
that 1st colorado is the nicest colorado i have ever seen...
Fire red is back for the All-Terrain package.
Maybe they'll bring back the good AT wheels. I'm not holding my breath.
LOL...they still have them...but they're covered in plastic...
Next ones come covered with a thin sheet of aluminum foil shinny side out. That's the polished aluminum versions, and the rear bumper metal pieces are going to be 75% less metal. :lol::D
Fat chance of that.
Looks like nothing much changed, other then a couple colors.
I had hoped they would have updated the Nav systems to include XM weather adn some of the other newer features. Ford has had the Sirius Travel link service for a couple years now and I saw a Buik add last year that showed a similar system was now on one of the Buick cars. I sort of expected that system to miigrate to the rest of the GM models for 2011. I guess not.
I had hoped that the 6.2L would have made its way into the Suburbans for 2011, since it was available on the Yukon XL in 2010. No luck there either, also looks like the Yukon XL lost the 6.2L option for 2011. The 2010 Yukon XL was the last of the part time 4x4 SUVs with the 6.2L available. I guess the 6.2L was just a 1 year only option for the Tahoe (2009) and a one year only option on the Yukon XL (2010).
Anyone know when the 2010 Yukon XL order bank is closing, or has it already closed?
    250.3k
    user087
    user087
  • Who's Online   3 Members, 0 Anonymous, 854 Guests (See full list)
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
