Been Busy With Projects But I'm Back!
Well I used to get on the forums everyday several times a day but then projects started stacking up and our 4th of July trip to Michigan was coming up so I had to buckle down and get several projects completed. The most important was finishing building the motorcycle trailer I was working on to haul my two rockets up to MI for some riding time, from the pics you can tell it was a project but turned out great. I also had some side jobs on an Infinity G35X and Restored a Snap-on Harley Davidson Toolbox which was in a garage that caught on fire so I've been super busy but am now free and clear of any projects so it's nice to relax and spend time on the forums again. Here are some pics for you guys, I know how much you all love to look at pictures.
Here is the toolbox I restored for myself, bought it for $1500 after the guy tried to clean it up with no luck. the first picture is after he washed it with dish soap and still looked horrible. I stripped it down to the shell and scrubbed it down in and out to get all the black sooty stuff off. I repainted the drawers and top box door, replaced every piece of plastic on the box along with snapon emblems, drawer liners, all new lock/key assemblies, drawer latches etc. Turned out nice and gives me alot more tool storage than the smaller red snapon box I had prior.
Just when I thought the projects were done my wife lays down the ZX6R the other night so now I'm in the middle of repairing that!!! I'll find time sooner or later to claybar the truck and put a fresh coat of wax on her.
Great work on the projects!! :D
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
