Brake Rotors Rotting
I have a 06 Sierra 2500HD crew,4x4,6.0L. The trucks got about 44,000 mile on it. I rotated the tires last week and couldn't believe what the brake rotors looked like both the front and the rear. There junk. They have rotted away while destroying the pads.
I could believe this with 60k but this is way to soon. I just got back from the parts store and close to $400 later I have new brakes parts. Replacing the rears today what a PIA it has been. I can't get the calipier bolts out I've gone through 2 torque bits already and have no idea how to proceed. I've heated them,used vise grips,breaker bar all with no luck. Any ideas?
i would imagine the rotors are diff on a 2500 from my 1500, but i ended up having brake / rotor probs @19k miles , and as of a month or 2 ago it turned out to be the calipers were hanging up which was causing the premature rotor failure.... so the calipers might be something to look at
I want to post the pictures I took of the rotors but don't know how to scale them down. It fails because the files are to big. You wouldn't believe what these rotors look like.
You'll have to resize 'em at whatever photo site you use first.Check into a little tool called an ''Impact Driver'',it's done wonders for me :)
I could believe what they look like, the rotors that is.. Tell me more about this rotor hang up problem. After I had all new rotors and pads put on, I noticed what sounded like the DS rear calipar sticking. It would non stop squeek and the only way to get rid of noise was to apply breaks. It did eventially go away, the squeeking noise and doesn't seem like it is hanging out. I did change style of rotors to slotted kind that self clean and gotten used to the new noise that I've gotten accustomed too when breaks are applied. They also have finally slowed down on leaving a huge mess on my wheels like they did at first for the break in period.
I've read stuff about GM's rotors they used, but am not about to judge GM or come up with an opinion of them until I see how these aftermarket EBC rotors and pads wear and if they eventially rust/rot. I am exposed to salt in the winter, and salt is brutal on a truck or any vehicle for that matter.
The rear brakes (rotors, pads.) on the 1500CC trucks are heavier than RC/CC, same as 2500HD i believe.
I have 140000 kilometers on my 06 2500HD and the rotors are still like new?
maybe you just got a dud????
This is a common problem, and not just on GMs. Im an Auto tech and see it very often on most makes. I am in the NE United States. I wonder if they have the same problems in Arizona, or New Mexico.
My rears are rusted out on my 02 HD - I am doing them tomorrow - I will let you know how I make out.
Finished them up with barely any issues. I used GM Ceramic pads and Napa rotors.....lets see how long these last.
wow that is terrible 40000 miles on a set of brakes. I have a 2004 2500 with 200000 miles on it and my factory brakes lasted me 190000 miles. I do have a manual tranny and down shift which I thinks helps but not that much. My last truck a dodge was terrible on brakes. I had to replace every thing every 40000 miles like clock work. Good luck on this next set.
I've got a 2003 2500HD and lemme tell ya...68K and I'm on my second set of brakes in the rear....so I burned through the originals, had a replacement set put on and now I'm on my second replacement set. I've finally given up on the expensive parts and am putting the cheapest Chinese crap I can find rotor wise. From now on, I'm treating the brakes like an oil change. Just plan on replacing them every year or so. The fronts have only been replaced once...but both front rotors had to be replaced because of sticking...to the point of wheel hop going down the expressway. Yeah, that was fun that ride home.
I was assured with the first replacement set that "GM had fixed the problem". Yeah, right. $450 later (for all new parts on the rears). I ponied up for Napa rotors and ceramic pads for the front and so far they seem to be lasting. But the rears just get hammered.
They salt the hell out of the roads around here because everyone drives like idiots, so it's not all GM's fault. And I don't drive the truck every day (hence a 6 yr old truck with 68K)...but it does get driven at least once a week for a good distance.
I would bet that they would last forever in the Southwest. I lived in AZ for a few years and working on 30 year old cars was a snap. Everything turned given a large enough cheater. The rust there was just surface rust. We changed front springs on a '53 Ford dump truck with nothing more than a 3/4" socket set and a 3' pipe.
Good luck.
I finished up on Friday doing the front and rear pads and rotors. Let me tell you what a PIA the rears were. Those F-in tourque calipier bolts were unbelievable. No matter what I did I could not get those to move. I did everything to get them off. Finally I gave up and removed the brake lines and took the calipiers to the shop. They even had a tuff time with them with air tools,heating,breaker bars etc. But after about 45 minute they got them all out. Another issue I had was that I needed to grind down the back plates of the brake pads. Just needed to take alittle off so the pads would slide on the slides.
The end result is the brakes feel great now.What a difference.I really hope these rotors last more than 44,000 miles.
With Rotors and living in an area which gets snow and ice and road salt is used to treat it, you gotta get that salt off those rotors as fast as possible. Alot of people won't do it in winter because it is too cold outside to be messing around with a hose and water. 70% of repairs comes from salt damage on my vehicles. In the past, brake lines, cooling lines, rotors, manifolds, fuel lines, all have rotted out because of prolong salt exposure. However my soon to be 16 year old Mustang GT has never had any of the following replaced yet, because it is not driven in the winter time.
I really think for the nbs trucks, those wheel well inserts are a good investment! They will pay for themselves over time. But in the meantime a power washer is your friend and will get that salt off..Just don't forget to bring it inside in winter time to a heated building or you risk having remaining water freeze inside pump and possible damage the pump.
    • I understand. It is disturbing to think a manufacture asks so much and gives so little in engineering support. This is not a GM issues, this is a greed issue and one the ALL practice.    My intent was not to remove the wind from anyone's sail but rather to point out the areas deficient so that they can be discussed with improvements the goal. But to do that you have to know the truth and what that truth is.    The commercial interest are honed in on a few select issues in which they control all the variables and are not forthcoming in the least with their customers about the details. Failure is the only thing that drives these people to improvement. One way not to fail it to manage public "expectations". The set a bar they can clear and put their thumbs under the suspenders with chest puffed.... Only the internal data tells the story fully. As we don't have access to that for decades then we have to generate it ourselves. UOA's with data that matters.
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
