New Tsb For Trans. Pan Magnet
Looks like they updated this TSB to include the 4L60 transmissions.
From the TSB:
TSB # 08-07-30-040B
Revision released May 5, 2009
2002-2009 Cars and light duty Trucks with 4T40, 4T45, 4T65, 4L60 Transmissions.
A new transmission oil pan magnet, P/N 29535617, was released for service. The current square transmission oil pan magnet may become saturated with normal ferrous sediment and the Pressure Control Solenoid (PCS) is now collecting ferrous sediment, making it vary from design. For a given current, the PCS electromagnet is stronger, causing the line pressure to be less than needed.
The new updated part replaced the square magnet with 2 round magnets.
This TSB should only be performed under normal maintenance or warranty repairs on the transmission.
Found it on Amazon for $15.71
Product Details
  • Shipping Weight: 0.8 ounces (View shipping rates and policies)
  • Shipping: Currently, item can be shipped only within the U.S.
  • Note: Gift-wrapping is not available for this item. Darn, Christmas is just around the corner too.
  • ASIN: B0016J3W90
  • Item model number: 29535617
  • Average Customer Review: No customer reviews yet.
Also found it at Rock Auto as:
ACDELCO Part # 29535617 $7.97
Category: Oil Pan Gasket* Non-stock item--shipping delayed up to 12 business days
AKA
MAGNET,A/TRNS FLUID PAN w/6-SPD A/TRANS(MYC)
MAGNET,A/TRNS FLUID PAN w/6-SPD A/TRANS(MYD)
MAGNET,A/TRNS FLUID PAN w/6-SPD A/TRANS(MYB)* Non-stock item--shipping delayed up to 12 business days
And at Merchant Automotive it is there as:
Allison Spin on Filter Magnet $4.00
Allison installed a disk type magnet that mounts on top of the external spin on filter to catch metallic debris. Its very common for this magnet to get overlooked when servicing as it tends to stick to the top of the filter, only to get thrown away with the old filter.
http://www.merchant-automotive.com/allison...ltermagnet.aspx
  • 1 year later...
    • I agree.   However, the owner's manual, suggests that a drop over full is just as bad as a drop under. (Read black and white letters only, insert no common sense.)
    • That P0700 and loss of power suggests something significant is amiss to me.   More/other codes may suggest otherwise; I would investigate those prior to spending the money to change fluid on a transmission with a bad torque converter.    The relatively sudden escalation of symptoms to me suggests that something began failing (initial shuddering experienced) and rapidly deteriorated (slipping/loss of power). Fluid condition alone wouldn't cause the sudden escalation of problems - though it might have been the cause of the deterioration up to the point of failure.
    • Stabilitrack operation is in a sense a separate/independent operation from the operation of 'traction control'. Stabilitrack is used to keep the vehicle traveling in the DIRECTION intended, it can brake independent wheels and or adjust throttle to influence the direction the vehicle is moving.   This can be illustrated by a 'fish-tailing' example. At high speeds, if the stabilitrack detects excessive yaw (the vehicle spinning like a top, it has a sensor for this), based on inputs from steering angle it determines that the vehicle is spinning out of control, and begins working to control that unintended spin. By reducing throttle input or braking specific wheels to control or prevent the spin.   The traction control works similarly using the ABS system to slow spinning wheels and thus transfer power to 'other' wheels. The goal being to achieve wheel speeds that are all in agreement with each other, the truck then assumes that since all the wheels speeds are the same no spinning is occurring. For example, launching up a wet boat ramp, there is no excessive yaw present, traction control alone can manage the wheel spin by braking spinning wheels and cutting throttle.   Stabilitrack and traction control from a hardware and software standpoint are basically one in the same, I don't remember specifically in 2004, but you couldn't get a truck with one and not the other. The switch on the dash, could turn off the traction control, but not necessarily the stabilitrack.    A confusing comment about stabilitrack vs. traction control, the same components serve both operations, but marketing could advertise them as two separate features.    The AWD system is another separate system entirely, in addition to the other two, it uses the same wheel speed inputs but can also vary the transfer case clutch application to direct some power to the front axle, working in conjunction with the traction control to bring wheel speeds together.   The power split will never be greater than 50:50, the same as 4-high. It will never direct MORE power to the front axle than the rear.
    • Not based on the new photos I'm seeing.  Car and Driver posted additional photos that shows an auto stop start button left of the steering wheel.
    • Car and Driver is reporting wireless CarPlay WILL remain, and they posted several additional photos, including a left knee shot, but the only hard buttons there are e-brake, auto start stop, tailgate and cargo light.  Also definitely looks like High Country and ZR2 get micro fiber on the center of the console lid and the ZR2 possibly also on the seats.
