I know it's a ford pulling the boat guys but I didn't have a picture of my truck pulling the 2 rhino, 18' trailer, and my sportman touring in the back of the truck. I'll have to post it later.
This is what I pull daily at work.
Geez Jamie, what is the tongue weight on that thing? The front tires look to be floating!
Boat and trailer is about 9000 lbs. It's a 26' SeaArk with a 350 in it. We car an extra 30 hp motor on the back. It has an on board 7.3K generator. It really squats the poor little F350. I'm guesing there is about 3000 lbs tongue weight.
Not my truck but GM truck none the less...... Too bad Toyota fans.... Yes, that would be a CHEVY pulling the TOYOTA racing trailer!!!!
I saw these pictures a year ago or so. Googled and found them again...
Jbo
Jbo
Ha! That's funny. :lol:
the F-350 in my post above has the V-10 6.8L in it. It's a real turd on hills and it averages about 6-6.8mpg pulling the boat. We have about 25000 miles on the truck and 23,000 of them are towing that load.
Jbo
That is hilarious, any Toyota forums that these pics should be posted in? :lol:
the ford v10 is an awful engine.. no more power then a v8 and god awful gas mileage and from my expirences bad reliability...
that looks like a 1500. and what kind of car do you tow in that trailer? i have to go pick up a buddy's 69 camaro with an enclosed trailer in the next month or so and was curious to know how that handles?
here is a pic of my old 03 (4.8 and 3.42 gears) pulling my freshly powder coated frame home from the shop.
The 03 wasn't enough to pull the Monte Carlo once I got her back together so I picked up my 09 with a 5.3 and 3.72 gears
I would love to have my own trailer, but I just don't have the space for one
Edited by DoMDrty
Post lift towing pics. not much sag if any at all. the first pic is on a hill so it looks tiltled.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
