Done With The De-badge
Ok so the drivers and passengers SILVERADO are gone.
I am torn about taking the Z71 off the back what do you all think?
Keep or scrape?
Remove it all. It looks so much better. I have been meaning to debadge mine when I get time.
Badges are just free advertising for Gm and show off details for the vain owners. Lose em!
Wow, I actually prefer to keep stock badges, I mean I think if anything its people that put 3 foot wide chevy bowties on their rear-windows that looks stupid.
I immediatly remove dealer advertising though, nothing a cheap hair dryer can't fix!
Yeah... Darren, my post was a bit of satire. I removed all of the tailgate badges off of my truck but the door Sierra badges are still there.
i tell my dealer to give me 50$ to keep their dealer name on the vehicle or theyhave take it off. out of 3 times, only one actually gave me 50$ haha
Ok the vote is in I will remove the rest of the badges this week. Thank you to all of you that gave me your opinion I REALLY appreciate it. I will post pics as soon as I get it done.
The weather has broke and I am taking the opportunity to go play in the dirt!!! :uhoh:
Ok I guess I'm alone but I like the Z71 stickers, but then I've never been one to de-badge anyhow. Dealer badges on the other hand, I instruct them to not put them on and if they "forget" I ask them to take them off before I drive it off the lot.
damn. you have the truck i was drooling over at the chevy dealer in fort walton beach, fl
You're not alone, I have no problem letting everyone know I'm proud of what I'm driving. I've always felt those that debadged were ashamed of their ride and wanted people to think it was something else instead.
Now if it were a Toyota I might remove the badges. :noway:
X2!!
X2!!
Now if it were a Toyota I might remove the badges. :)
You got me. I'm terribly ashamed of my truck. :noway:
:lol: .
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
