Ford Going To Dex-cool
I could careless what color it is.... JUST AS LONG AS EVERYBODY CHANGES IT... FREQUENTLY. I hate changing heat cores.........
Jbo
Edit: Forgot my reason for posting.... It was to state a dexcool system was the system that I NEVER did anything but change the antifreeze in. I changed the pump and thermostat before selling it simply because I did not want the new owner to have to do it later (which I feared 250K+ miles)....... Pump never failed 1995 - 2004, thermostat was the one GM installed in 8/94 also, and regretfully the upper and lower hose were removed and changed only when I changed the water pump in 2004. They were the GM hoses. I changed the heater hoses with Gates Green silicon hoses around 98.... Me and a heater hose clamp had a disagreement which ended with me and my die grinder.... (which I might add is the way I remove OE hose clamps, which I replace with lined screw hose clamps only)
Exactly. Don't do that stupid 100k BS. I will have my Dexcool flushed every 50,000 miles, as reccomended by mechanic friends who have had to change out more heater cores on GM vehicles than they have seen naked women. They are sick of it.
Jbo
Jbo
First cool weekend every fall I can be found changing antifreeze in pretty much EVERYTHING I OWN. Regardless of mileage, condition, mixture, brand, flavor, smell, color, etc, etc, etc....
Jbo
Jbo
Jbo
You're obviously doing it too often. You only need to change it when it stops tasting like orange Kool-Aid. :cool:
I'm all about the overdoing, versus underdoing as well. Same goes with oil. Cheap insurance for a $5k engine.
Do I need to change the coolant in my truck even if I have low miles on it? Is time a significant factor as well? The truck is 4 1/2 years old, but has only 16k miles on it. I certainly want to prevent any heater core damage if I can. Why does Dex Cool attack heater cores? Won't it damage radiators just the same?
I am usually the preventive maintenance guy. ANYTHING I can do to prolong or keep something from happening, I do. Who changes brake fluid, I do, every brake change or when the fluid is no longer clear... I pull the plug on the transmission pan every couple oil changes, and fill it back up. At least 2x a year I change differential fluid. etc etc
I dunno, why the heater core, but it usually goes first. ESPECIALLY if it has moving lines (they swing to allow installation). 4 1/2 years and I would have lost all of my finger nails (chewed off from stress thinking about that system eating something, jk).... but I would change it.... If not every at least every other year.
Jbo
Dex-Cool IS one of the most friendly coolants towards metals and corrosion.....
Dexcool probably has better performance on aluminum, steel, and iron and a longer life than most any other coolant. It has no silicates or phosphates to form solid abrasives (I don't think this is a big issue really) and is pretty tolerate of tap water that's not too low quality. It's pretty cheap and easy to find. Plus if your car has Dexcool already it's good to stay with the same formula if you can especially during the warranty period.
It certainly wouldn't hurt to do a coolant flush and refill after 4 1/2 years. The recommendation for coolant changes for vehicles with Dex or typical long life coolants is 5 years or 50K miles whichever comes first.
According to internal GM documents, the ultimate culprit appears to be operating vehicles for long periods of time with low coolant levels. The low coolant is caused by pressure caps that fail in the open position. (The new caps and recovery bottles were introduced at the same time as DEX-COOL). This exposes hot engine components to air and vapors, causing corrosion and contamination of the coolant with iron oxide particles, which in turn can aggravate the pressure cap problem as contamination holds the caps open permanently.
Dexcool really only had problems on earlier models that had poor gasket designs and the pressure cap on the radiator. When you add up all the advantages and disadvantages of coolants, Dexcool makes the most sense in a late-model GM.
4.5 years is definitely due for replacement. Eventually that stuff becomes acidic and it's all down hill from there. I would certainly change it.
Just about all MFR's are going to Dexcool in the future. Gm was one of the first to go to Dexcool in 1996 and as always a leader in technology.
Is there a coolant drain plug on a 5.3 liter engine block? If yes, where is it?
Yes, there is one on each side of the block. It is a big plug and requires a 17 MM allen wrench to remove. The one on the passengers side I believe is behind the starter so it will have to be removed to access the plug.
Thanks,
I assume the other plug is accessible. By opening only that one, only half of the block will be drained?
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
