Knock Sensors
i have been throwing a code for about 6 months deployed for 4 of them. i need to change the right side. if both are close ill do both. are they a b*tch to do? i want to know what im getting in to.
The "LS" engines have two under the plentum, follow the TSB for proper fix. Replace both along with the harness and do the silicone around the sensors.
i have to do the harness too? and TSB?
The harness and the silicone along with the KS replacement is recommended in the TSB and if you want to fix the problem and get your fuel economy back do it.
i noticed fuel econ a lil. 2 or so mpg's what i notice is it stumbles a lil between 3-4000 and its slow to take off. its dead til about 1000-1500, but after i start rooling its fine til i run it hard
would this apply to an 06 with the 4.8? just want to look forward to it on my friends truck if it does and give him the info
no i mean, can he expect the same problem soon. ive heard of this happeneing from 01-04
This is only an issue on LS engines up to 04. 05 on up are gen 4 engines and the knock sensors were
moved from the valley cover to the side of the block.
so what was the issue with the knock sensors thats common. what made a lot of them go bad
It wasn't really the knock sensors themselves, it was their location on the valley cover under
the intake manifold. Water would collect around the sensors and corrosion would occur wich
is why on the TSB they recomend a bead of silicone around them after replacement.
thats an issue gm should fix and not leave me to pay out the ass for
