6.0 Exhaust Bolts
I have two broken exhaust bolts and want to replace them. I have heard there is a new designed bolt, if so has anybody used it? Or is there a better solution? and how have they lasted? also what is a good gasket to use? any experience with this subject would be very helpfull
So far no problems with the bolts after having them on for over 2 years now. The bolts themselves have some special coating on the threads (forgot the name of it). It looked like teflom, but is not. They are designed to stay tight and tolerate the temperatures. Make sure you get the revised manifold bolts for the 6.0. They came out in late 2004.
Of corse mine must be and early 04 ha!!! Can you get them from any chevy dealership? Also do you have a part number? Also what gasket did you use?
I don't remember what it cost, warranty covered it along with new manifold. I think you can get them from Napa or other auto parts stores. I'm sure GM service centers would have them. With gasket, it came with new manifold which was manufactured for GM in Canada.
I just called my local stealership and they said they were $1.76 does that sound right? I also asked if they were the new design and they just told me they were the ones they always sell
they should be OK. when installing the new bolts, put some anti seize compound on the treads.. will make your life a lot easer later on..
$1.76 is spot on. I had to go to two different dealerships to get 12 of them. My question is, what should these be torqued to?
just did this today on my 01. Bought the revised bolts M8x1.25 with a larger diameter head vs the original style. As far as the torque specs go....11 lb-ft then re-torque to 15 lb-ft. hope this helps
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
