Blinking Security Light
My wife's Audi has a red security light that flashes on her dash when the alarm is activated. Can something like this be added to my '08 Silverado?
My first reaction was "sure just have an alarm installed" but I'm guessing thats not the route your looking to go. I think there is a orange security light in the gauge cluster. My only idea would be to pull your cluster, isolate that circuit and then wire up a LED to stick somewhere. For that much work I would revert back to my first idea and have an alarm put in.
go on E-bay and do a search for "Fake sercuity lights" cost you about $5 LOL!!
Don't have the money right now with Christmas just being over and getting ready to buy a house, so I thought in the mean time this might be a temporary solution (Anything to deter a thief).
I found this... http://www.ehow.com/how_4678201_build-fake...larm-light.html
Is there a way that I could wire it up on my truck without draining the battery? There has got to be a way that I can wire this into a fuse (or somewhere else) to where the light would be on when the truck is off or off when the truck is on.
any suggestions?
I had my wheels stolen off my truck at my apartment last month so I might be a little paranoid. When I can afford an alarm I will get one with an inclination sensor and shock sensor added.
any suggestions?
Did you have wheel locks on your wheels?
LEDs only draw about 10 mA when they are lit. The author of that article did say which LED was recommended and his solution seemed pretty complicated to me. I think if I was going to do this I would find an unswitched (battery) location on the fuse block or use one of the those add-a-fuse devices. Put the LED where you want it and run the 12V through a little toggle switch to the LED. I would not like a LED that blinks except when I wanted it to and I don't like the idea of getting into the steering wheel cover to wire things to.
any suggestions?
any suggestions?
Yea, that was the first thing I did when I got the new wheels put on.
That solution seemed pretty complicated to me as well. I figured that wouldn't work for my truck and I too would not want to go into the steering column to wire anything but just thought that if there was something like that that could be done with my truck and taping into a fuse I would do that (Tap into a fuse that will allow the light to be on when the truck is off, and off when the truck is on).
Maybe this is not anywhere close to being possible but it was just running through my head. I get the random thoughts/ideas in my head from time to time. Plus it's an excuse to work on the truck a little.
    • Conditions for Meeting a Cold Start   The ignition voltage is between 10 and 15 V. The barometric pressure (BARO) is more than 75 kPa. The engine coolant temperature (ECT) at start-up is less than 42°C (108°F). The intake air temperature (IAT) is between 2–32°C (36–90°F). The engine is OFF for greater than 6 hours or the following conditions must be met: The start-up IAT minus start-up ECT are within 12°C (22°F). The start-up ECT minus start-up IAT are within 50°C (90°F). Fuel level is between 25 and 75 %.   Circuit/System Verification Verify that all I/M System Status indicators report YES, and that no I/M Test DTCs are present.If any I/M Test DTCs are set Refer to Diagnostic Trouble Code (DTC) List - Vehicle. If no I/M Test DTCs are set All OK. Inspection/Maintenance (I/M) System Set Procedure   Warning: Refer to Road Test Warning. Note: Do NOT touch the accelerator pedal until told to do so. A change in TP Sensor angle or an increase in engine speed may invalidate this portion of the test.   Note: An I/M Test DTC will not be stored or erased from the ECU except at the end of trip processing, which occurs 5 s after ignition OFF.   Ensure that the vehicle meets the conditions for a cold start listed above. If the EVAP I/M System Status indicator displays NO, perform the EVAP Service bay test if applicable. Turn OFF all of the accessories; HVAC system, other electrical loads, including aftermarket/add-on equipment, etc., and open the hood.   Set the vehicle parking brake and ensure the vehicle is in park for automatic transmission or neutral for manual transmission.   Start and idle the engine for 2 min.   Close the hood, release the parking brake and Accelerate at part throttle to 72–80 km/h (45–50 mph) with this speed maintained until the engine reaches operating temperature, 8–10 min.   Continue operation under these conditions for an additional 6 min.   Accelerate at part throttle to 90 km/h (55 mph) with this speed maintained for 2 min.   Release the accelerator pedal for at least 10 s. This will allow the vehicle to enter the decel fuel cut off.   Safely stop the vehicle, with the engine in drive for automatic or neutral with the clutch pedal depressed and parking brake applied for manual. Allow the vehicle to idle for 2 min.   Shift the vehicle to park for automatic and neutral for manual. Turn OFF the ignition and exit the vehicle. Do NOT disturb the vehicle for 45 min.   Observe the Inspection/Maintenance (I/M) System Status with a scan tool. All of the I/M System Status indicators should display YES.   If the EVAP I/M System Status indicator displays NO, turn OFF the ignition, ensure that the vehicle meets the conditions for a cold start, and repeat steps 6-11 three more times, or until the EVAP I/M System Status indicator transitions to YES. If the indicator continues to display NO, refer to the Inspection/Maintenance (I/M) System DTC Table to identify the DTCs that did not run.   If any of the I/M System Status indicators display NO, refer to the Inspection/Maintenance (I/M) System DTC Table for the indicator which did not display YES. The I/M System DTC Table identifies the DTCs associated with each I/M System Status Indicator.   Observe the I/M Test DTC information with a scan tool. Verify there are no I/M Test DTCs present. If an I/M Test DTC is set, diagnose the DTC using the Diagnostic Trouble Code (DTC) List - Vehicle and refer to Inspection/Maintenance System Check.   Observe the engine DTC information with a scan tool. Verify no DTCs are present. If a DTC is set, diagnose using the Diagnostic Trouble Code (DTC) List - Vehicle. After repairs, perform the Inspection/Maintenance Complete System Set Procedure to verify no further DTCs are set.       Looks like one procedure to me.  Repeated as necessary.
    • My 2020 AT4 6.2 has had the valve spring issue addressed at ~200 miles, front cover/pump replaced at 18k, water pump at 34k and idler pully at 65k.  I would agree with ditching by 100k unless you elect to go with upgraded hardware...say built 10l80 and an lt4 or l8p swap.
    • I also need one of your modules for my 1993 chevy c2500 7.4 Thanks! My email is [email protected]
    • Chevy needs to do a black regular cab short box SS model with the new 6.6L.  400SS.
    • You might find the drive cycle you need somewhere on charm.li (website), otherwise I suggest a subscription to alldata.com to get them for your truck.
