New Gmc Owner
350camaro
I am returning to GM from the dark side, a few weeks ago I traded in my 04 F350 6.0L diesel for a 2011 GMC Sierra 1500 crew cab SLE 4x4 5.3L with 20" Chrome wheels.
welcome, so how do you like the GMC comapared to the ford?
I love it, the ride is nice and smooth, and it handles great with the 20" wheels, I also really like the auto 4x4 mode.
yeah i can imagine it would ride like a caddy compared to that F350. the 6.0's were shit anyway.
the auto 4wd is a nice feature
Welcome, you got some pics?
The only pics I have are the ones from the dealer's internet ad. It keeps snowing here, and with all the salt on the roads I have not had a chance to take pics while it is clean.
I had nothing but problems with the 6.0, I am glad to be rid of it. It was not so bad while the engine was under warranty, but over the last two years I spent 3,500 in repairs not including normal maintenance.
just curious, what were the repairs, one of my buddies has an 04 F350 6.0 CCLB and he had the infamous head problem year ago and just a few months ago something was really messed up with his cooling system... he has spent over 6000$ in repairs and still dosent like the truck. it rides like shit
While the truck was under warranty it had lot of EGR problems ( once or twice a year), 2 injectors were replaced, chirping serpentine belt, and a few other things.
The 3,500 in repairs was for the EGR system, both times EGR valve was replaced and the intake manifold was taken off and cleaned in some kind of chemical bath to clean the carbon out of the EGR passages. The second time the removed the intake, last summer, they were supposed to put on a new intake manifold but after the dealership took it apart they found out the intake was on national back order.
For the last six months the truck was having intermittent injector problems, my AutoEnginuity scan tool found injector codes that were pending but the engine light never got set, of course the Ford dealers could never find anything wrong with it. I decided to get rid of it before I ended up with an expensive repair bill for the injectors.
Nice Truck
    • My house is set at 75. My car at 70. When I have guests the house is at 70.
    • OK you say you could hang meat but what was the actual temp? One of the AC systems job is to remove humidity that we feel on our body your new system removed alot of humidity as that is were the water comes from on the ac coils and that made it feel colder. 80 degrees with high humidity will feel hot vs 80 degrees with low humidity will feel alot cooler.
    • I was using recirc/max air. Especially if it really hot i start out by lowering the front windows a little with regular ac the go to recirculation after a few and rolling windows up. And it does not have the newest refrigerant. It has per the info under the hood r134. Not the new r1234yf.
    • tldr; Shade tree mechanic stumped by variable displacement AC compressor.   Not Silverado related, but for my 2000 Camaro SS. I've never really used the AC since acquiring the car a good handful of years ago. I plan to take it on a trip this summer so I wanted to make sure the AC was in good shape. On an 73 degree day in the shop with the car idling I set the AC on "Max", temp set to cold, and fan on hi. The compressor turned on and air turned nice and cold.   I let it run for several minutes but noticed the compressor never cycled off. The engine was up to temperature enough that it began cycling the cooling fans on high. I had a set of manifold gauges hooked up and it was consistently at about 25 psi on the low side and between 200 and 225 psi (warm engine) on the high side. Per temperature charts, the low side is low (should be 30-35) and the high side is a little high (up to 170 per chart). I read the low pressure as potentially being under-charged underscored by a continually running compressor This was also underscored by temp readings of mid-20 degrees at the vents. Not just cold, freezing cold. Switching off the AC but leaving the HVAC fan on high produced a deluge of condensation underneath the vehicle. I was getting ice buildup on the evap core most likely.   The low reading (25psi) concerned me that the compressor wasn't switching off so I swapped out the pressure switch. No change in behavior, still ran constantly.   The AC clutch works fine as it engages/disengages with the HVAC switch on command. The compressor relay is good as I swapped it with two different known good relays just to be sure. Having eliminated that, and the pressure switch, I added refrigerant, thinking the constant run and low "low" pressure were signs of a slight undercharge. Makes sense, the car is 26 years old and it doesn't appear the AC system has ever been touched.   Adding some R134a didn't meaningfully change the low side pressure. And that's when a lightbulb flashed upstairs. While I consider the car "old", it's possibly "new" enough to have a variable displacement compressor. Did some reading and sure enough. Dangit. I don't work on these for this reason.   Adding refrigerant means the compressor will just compensate and won't really change pressures until it's severely overcharged or undercharged. But at least I wasn't getting ice/frost anymore, but instead high 30 degree temps out of the vents. That's more normal, but with variable displacement now I have no idea where my charge level is at. It's probably overcharged now. The high side even with the engine radiating serious heat was never really over about 225.   The static pressure at room temperature is dead on, before and after the charge. Both high/low equalize after some rest.   I'm thinking I'll need to take it to a shop. I want the proper charge level so I'm not working the compressor too hard. The only way to get an accurate charge is to evacuate and then re-charge with the exact amount specified for the system -- at least that's what I'm reading.   Anyone here with modern automotive AC knowledge?
    • Mine is in the shop for the AC now. While it did get cold after a bit, it would take a while to even start to cool the air at all. Turns out the compressor was bad and cycling.
