Bose Speaker Questions
bud4ya
Can anyone tell me if the Denali with the Bose has different speakers than a non Bose system? I am assuming yes? Also des anyone have a part number and pic of a Bose sound system speaker and a non Bose sound system speaker if they are different?
This is n an 08 Denali. Dealer is putting in new speakers to replace aftermarket ones that are in there. I just want to make sure they are not cheaping ut and putting in regular speakers rather than the ones that wuld go with Bse sound. This again if they are different. I just want t be able to have them pop the speaker cover so I can look and make sure they are replaced with the ones that would have come with a truck that had a Bose system. Just dont knw the difference between what a stock speaker or a Bose speaker would look like.
Thanks
They may not look that that much different. You may have to pull a product number off of the speaker and run it on google. Or it may be marked Bose of the rear, on the magnet. OR you could turn it up and check its quality. Theres a huge difference between the bose system and the factory system if you have an ear for sound.
It would be nice if I was able to see a pic of both and see if there is a visible difference. If not good idea on just checking the part number. It has to be on the speaker somewhere. Anyone know where I can get the part number for the bose speaker and a non Bose just to check it out? A pic of a Bose and non Bose speaker would be key if they look different.
Thanks
Hissing noise is gone now that stero is back to stock. The factory AMP was bad becuase the spliced of that to after market one. If they would have gone direct to new AMP factory would not have been toast. So now I am out $800 but hissing noise is gone.
Gues I will sell the after marke Memphis speakers and AMP and re cover some money
Here are what the Bose speakers look like.
I personally do not like the sound of the factory Bose speakers. I want to replace them in my wife's TrailBlazed but she doesnt have a good ear for sound and thinks they sound fine. She can't see spending the money. I personally went with Infinity Kappas all the way around in my Silverado. I am very happy with them.
I have a buddy that has a 05 with the bose sound. He has always thought they sounded great, and his wife (who does not know good sound if it bit her on the ass) thought all stereos are the same. I had a bunch of work done to my stereo (amps, speakers, line out adaptors and sub) and let them listen. My buddy now wants to change his to be like mine and his wife cannot believe she thought theirs was just fine, all stereos sound the same.
I like the bose systems pretty good. It sounds a lot better than factory standard. But I still think it could be better. I mainly wish mine had a lot more power a volume. I would have though the memphis would have been way better. Except for the hissing, how was the memphis speakers. Really loud?
How do you like the Kappas? I'm thinking about replacing the stock speakers in my 2011 Silverado crew cab (doors only).
Completely replacing the Bose system sounds like a lot of work. I added a sub to my Bose system so I'm mostly happy with it. I would love some kind of tutorial though that went for replacing the head unit, new amp, and how to conect to all the speakers. That starts getting over my head.
I love them. I've had them since July of '08 and would have a hard time finding an equivilent sounding speaker for the price. I put the Kappa 60.9cs components in the front and the 469.2cfp 4x6 plates in the rear. I did attenuate the front tweeters they were a little bright for my liking. Thats just a simple crossover setting.
heres what they look like all mounted up.
I modified the factory tweeter bracket to hold the Infinity tweeters.
all in all, the factory stuff is junk. I don't care what it says on it, monsoon, bose, whatever.
you really paid 800 for a new factory amp???
No they pulled out all the aftermarket stuff and re wired the whole truck. They put in new speakers, amp and wiring harness. If I would have known 800 going into it I would have kept the aftermarket equip. The hissing nise I had is gone which was really pissing me off.
They completly gutted the inside of the truck to re wire. Can you tell me what sub yu went with and how hard was it to install? I am assuming there are only certain sub's you can you use so you don't fry the factory amp.
  • 4 weeks later...
Has anyone replaced just the bose door speakers and kept the head unit and bose amp. I have a 2009 Sierra with bose and wondered if just replacing the door speakers would improve sound over stock bose speakers. I would keep factory sub, tweeters, head unit and amp.
I am curious on the speaker replacements for the Bose speakers as well. I am having a JL13tw5 and 500/1v2 slash amp installed on Saturday and really only want to changeout door speakers without the remaining amp and headunit process to go through. My understanding is the stock Bose door speakers are 3 ohms so if you put in 4 ohm speakers it would seem you may lose amp rms wattage but if you go 2 ohm do you overload the Bose amp?
    RyGuy43
    RyGuy43
  • Who's Online   1 Member, 0 Anonymous, 396 Guests (See full list)
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
