Got the beast cleaned yesterday. Obnoxious there in the background gets cleaned Saturday.
Of course it rains today though...
Nothing wrong with taking care of her just because she's older ha ha.
Everything I've ever traded the dealer just takes the plate off and puts it right on the sales lot.
They know how well I keep them up.
Haha! This is the first good cleaning I've given it on the outside since I bought it almost two years ago. If someone didn't put dents in most of the body it would look even better.
Murphy's Law... this is usually what happens to me.
3f37ca8e90e4547b6f755d00a1621a54.jpg I didn't do a thing to my trucks today but I drove this completely restored beast its a 1975 6030 JD. JD rated it for 177HP new but my boss said at around 12 000 hours just before it was restored it twisted out 225HP on the dyno . my boss has owned it for over 36years it pulled a 35ft cultivator up some nasty hills with its front tires off the ground all the way up the hills and you'd steer it by the wheel breaks (try that with a Case and it would break the JD did it for 30years still going)
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
