Decorated mailbox
Ryan
haha...Ya figured that out after I took a second look.
Before Fall slips away
That shine! :thumbs:
Hello to all! Trying to figure out this forum and it's pretty late. If this works y'all should see a picture of my 2015 Black Widow! Looking forward to sharing and learning. Thanks!
Just waiting on my front level kit then it's complete
Woah, didn't know they made streets at that severe of an angle. Your parking brake must get some serious use!
Hello all...Just picked up my new truck on Friday. My first GMC. I've always had Ford or Chevy. It's also my first truck with a lift (6 inch Fabtech) so I'm a little nervous about that, but love the truck overall so far.
Welcome and good choice on the truck, it looks great. Also, I wouldn't be worried about the 6" lift kit either.
Sent from my SM-G900P using Tapatalk
Thanks! I took her on her first road trip from Dallas to Fort Worth today and I'm really happy with the overall ride. She's smooth!
It is very solid. Not a spot of rust on it and a 25 year old truck with 225k kms in SW Ontario that's an impressive feat…
I love the truck, but it needs more power. I'm planning a LS swap in the future, probably a 4.8 or 5.3… Either are a power improvement over the stock 305 I have now…
I had an 89 Silverado. Had the 350 and we put 360k miles on her. She was a part of the family!
Sent from my Nexus 6 using Tapatalk
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
