Thanks for sharing your inquiry. You can purchase a copy of the vehicle invoice/build record (documentation of the vehicle cost broken out by model and factory options) by visiting www.gmmediaarchive.com.
OK, that really helps. My 6.5’ bed HC sticker says 1,359 lbs., didnt see that small print. Subtract me and some stuff, gives me about 1150lbs. So based on Google for hardwood (1500-2000 lbs), I’m making 2 trips for the 1/2 cord. Problem solved, thanks.
I went to Home Depot last week and experienced an upgrade push. Unfortunately, since then the Auto start/stop no longer works which frankly is no great loss. However the loss of the front bumper sensors has me concerned, as I had other computer problems a month ago with the fuel gauge and cruise control failing completely. Had to take it to a a dealer in NC for repairs.
I had the same problem on my 26 Canyon. I went into the setting page and toggled the speed limit indicator into the on position. There was no need for Waze or Google Maps. The speed limit no shows in the HUD as well as on the dash. Hope this helps.
