Universal Home Remote
i was curious. i am thinking of slowly converting my SLE to an SLT. yea i know it wont be easy or cheap. but i would like to have the home remote because of 2 garage doors and an electric gate. was this an option
Chances of finding a used console of the right color are slim, A new one from GM can be expensive, however.
I have 2 of these consoles in my parts inventory that I can put up pictures if you'd like. They were from 2003-2006 Suburbans without the sunroof. You simply remove the AC controls and put in the pocket frOm the truck console.
I had the Umiversal Home Remote on an 02 Yukon. The range on mine was terrible. I had to be right in front of the door before it would work which was about 15 to 20 feet from the opener itself. This was the same for 2 garage doors. I now have it in a 2011 Tahoe and it works great even from about 100 feet away. I don't know when they improved them.
Looks like he has 2 needles in a haystack :dunno:
Very simple to do. You just need to get the Homelink section (or you can get the entire console) and wire 12V power to it. I even added one to my 1994 C/K. Here are 2 styles on ebay:
http://cgi.ebay.com/ebaymotors/GM-CHEVY-GM...=item336c711ab2
http://cgi.ebay.com/ebaymotors/CHEVY-SILVE...=item4aadbfc97b
And if you search ebay for "homelink" you'll find a bunch of different button combos that you could mount just about anywhere (they even make one that fits into your sunvisor or you can buy a rearview mirror that has the buttons too).
Those seem to be good prices.
ill have to look into this on payday next friday. all the headliners were the same color right? i have dark interior and a light headliner.
and for sh*ts and grins any one know about this on an 09 G6
    HWN808
    HWN808
  • Who's Online   3 Members, 2 Anonymous, 966 Guests (See full list)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
