Sorry, im actually an EFIlive guy. I just have hptuners because its popular with my friends and instead of having them try to converty efi to hptuners i just scanned the tune out of my truck.
If you have EFIlive scan tool i can post up some logs that i took while tuning.
Can you export them to a spread sheet so everybody can view? I tried to upload one mine but it wouldn't let me. You might try???
Edited by CRSilverado
How about a complete pass from zero up? Or do you mean what configuration do we want to see? Time, rpm, speed, tp, timing advance, kr, MAF (Hz), Engine and tranny temps., current gear, manifold vacuum and of course afr.
So bottom line about e85..is my 2011 6.2 quicker or slower on e85? Stock tune for now.
Based on what I see in the tune for my 2013 assuming yours is the same you will be slower on E85 without tuning.
With the NHT pkg/ 3.73 & 9.5" rear end, anyone with this configuration on their L9H running Amsoil in front and rear diff? Did you see any jump in mileage?
From gear oil :crackup:
Hey "ex-150", that is sorta what I was thinking, but wanted to ask. Thought I read somewhere a guy claimed 1mpg better. You use Amsoil in your diff's? Thanks.
'12 Sierra 4x4 SLT 6.2l 3.73(NHT)
BBP tuned.
BBP tuned.
I am still on all the original fluids, all but the engine oil. My truck only has 23K miles on it. I am running 0W-30 (Mobil One) instead of the 5W-30 that is recommended and I have not noticed any difference in MPG, but that was not the reason for me switching to this weight.
It is the placebo effect of virtually every possible mod ever done to a vehicle after leaving the factory. From what I can tell, every mod adds 20 hp, but the debate is still between 1 OR 2 mpg improvement. Have seen forum posts(on other sites) where people were debating the effect of wax on mpg. Better wax, better mpg posts to boot. :nonod:
That said, have not changed the gear oil on the 2013, but when I did the 2007 dually some years ago, it was some ugly(factory)stuff coming out. Put Schaeffers back in & just did the semi a month or so ago. Small side note, neither showed ANY fuel mileage improvement but were due from a mileage standpoint. :thumbs:
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
