Trying to decide between a 4.8 and a 5.3L
I'm trying to buy a crew cab Silverado, newer body style, I have a 7500lb boat (that includes the trailer). I've read around and the towing capacities between the 4.8 and the 5.3 seem to be pretty big, so if I get a 4.8 and put a cold air intake/a few other things to increase the torque/power, will I blow out the transmission, or the motor if I tow the boat? I need to tow it about 1000 miles this summer, so a failure of any kind would be pretty bad...
  • Replies 34
Well i have an older body 4.8 with 113,000 miles on it. it has cold air and exhaust and a tune. i towed a 10,000 pound trailer up and down steep grades with no trailer brake. no failures. the tow was about 500 miles total
i personlly wouldnt get the 4.8. the 5.3 is faster more powerful and gets better MPG's. 4.8 is obsolete.
i have a 2003 4.8 and a 2001 5.3. 5.3 is way better to drive hands down.
Ok so your main concern would be the rear end gearing, and cold air intake is a waste of money. Total towing capacity is not much different at all between motors, about a thousand pounds, its because if you get a 4.8 they can come with a 3.23 gearing and the 5.3 don't come with that. For the wieght your going for your going to need at least 3.73 gearing with a 5.3. depending on the style of body (reg cab crew ect.) I don't think a 4.8 will work for you. Unless you bought a 4.10 geared 4.8 reg cab.
Some configurations a 3.73 gearing won't even be enough with a 5.3. Now this is with the 4L60e equipped trucks only.
agreed. i got my truck used. i would prefer the 5.3 but the 4.8 can get the job done for you
Ok so to tow my travel trailer again i should change my gearing? i have the 3.42
What you do and what it's rated for are 2 different things, I'm going with what's in the owners manual for my truck.
enough thread jacking, i agree with the 99%rs get a low geared 5.3
hell even a 2500 with a 6.0 and low gearing if you dont have duramax money
I would but I heard diesels don't like to be under worked, I'm more concerned about blowing the transmissions, from what I understand the motors seem to be pretty happy with whatever you throw at them... I know someone tows the same boat with a 2005 GMC yukon with the 5.3, and he said he's happy with it, I just didnt know if the tranny's are different and if theyd blow, also the 6.0's from what i hear get pretty bad gas mileage, not much worse then the 5.3's, but still on a day to day driving basis I dont want to pay for the extra fuel.
Then you've answered it yourself, low geared 5.3, just make sure whatever configuration you buy (6 speed 4 speed with correct gearing whatever) is rated for your 7500lbs boat, either way the transmission will die a little faster the more you tow. I don't tow boats, but I know for a fact a 4x4 is your friend on the ramps pulling it out.
The further from the max capacity you are the better.
Automatics are a crapshoot some fail early and some fail after 300,000 miles without a service.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
    • Fix one problem and find another.   Truck didn't have a thermostat in it so I flushed out the system today and refilled with 50/50 Dexcool. This truck is so old (LOL) that it has a sticker under the hood alerting people to the fact that it contains such. There is also an orange supplement with the owner's manual alerting the owner that "Your vehicle is one of a number of late production 1995 General Motors vehicles that use a newly developed engine coolant in the cooling system..."   I was still a little flummoxed by what seemed like a rich condition (exhaust smell, and a puff of carbon with a punchy rev). While watching the coolant temperature and testing the thermostat with my scanner, I happened to notice the IAT (incoming air temperature) to the intake was -40F. I know the temp is below average today, but I can still feel my face, and I was wearing shorts.   D'oh!! I realized I had never plugged the IAT back in, and the airbox was out while I was doing coolant. So I paused, reinstalled the airbox and plugged in the IAT, and viola. Things cleared right up, and I watched the coolant temp climb to a reported 198 degrees on the scanner (195 thermostat) and then it dropped to 194 (open) and then back up to 198 and held. Let it cool, came back, checked the coolant level and was satisifed.   Victory lap?   It needed more than the couple of gallons of gas I put in it from almost bone dry, so I ran it up to the gas station. It had earned it, or, at least I was pretty certain I wouldn't be draining or removing the tank anytime soon.   CEL popped on just as I was cruising a nice steady 40mph, just after coasting down a slight downhill curve.. Of course, it did, because, why let me enjoy not having dash emojis for a little while.   I just happened to have the scanner plugged in. I don't text and drive but I might scan and drive. Don't tell the police.   P0401, EGR flow insufficient.    Well, hello, EGR... ...my old friend! Welcome to the party, now that the engine reaches the factory-programmed operating temperature. I'm sure it was gagging on hostile, rich exhaust and carbon this whole time so I'll take it off and look again.   At least it's easily accessible, and worst case, about $65 to replace.   To keep, or to sell... Hmm. I want it running correctly either way. It's easier to sell when there are no fault codes.   It needs tires (they're aged out and cracking)   It could probably use an oil pan seal, or maybe the timing cover gasket/ junction with the pan needs redone because I've got an issue there that leaves a drop of oil on the floor.   If I do tires I'm sure they'll say the ball joints could use freshening, and, and, and, and.... At some point I'll have to stop. I can't (shouldn't) make it perfect, that's not what this rig is.
    • Take it back. That's about all you can do.  Mark
