classic II Wheels, Need polishing tips
I picked up a set of 4 classic II wheels on ebay for $350 including shipping they just look like they need a good cleaning/and polishing...Id really like to get them to shine& look like new.
So im just wondering what you guys think would be the best product to use,Thanks
s
http://www.autogeekonline.net/forum/how-articles/40091-how-determine-what-type-wheels-you-have.html
Ryan
I couldn't find it but mike Phillips had a great article on polishing rims I will continue to look for it
Ryan
Mothers power ball or Flitz ball. Personally I like the Fitz ball better because it's cloth rather than foam. :thumbs:
So i used mothers mag&aluminum polish and it did great day andnight difference but it still needs more and could be better, depending on the product does speed matter when rubbing it on..Like is by hand better or should i use the drill with a ball or pad??
I added a topic similar to this in the Rims & Tire section of this forum. I didn't get much advice over there either. The best I could find was a pre-cleaner that Flitz offers that you use before polishing and then pretty much do like you did and use a power ball or buffer of some sort to work the polish. Flitz also has a wax that you can use on polished aluminum wheels that helps to seal the metal so you don't have to polish them as often. The only advice I can give you is clean the power ball and polish it again. If the rims are oxidized pretty bad it can take a lot of work to get them to a high shine again.
  • 1 month later...
I use a Meguiers DynaCone and it works great getting in the holes of the MT Classic II's (I have same wheels). It came with a small sample of some kind of wheel polish, I believe it was called Hot all wheel polish, and it made my wheels shine better than I could get the mothers mag and aluminum to do. Don't forget that these wheels are polished aluminum, so you must buff them often to keep the shine, and make sure your wheel cleaner says safe for ALL wheels!!! I made the mistake, and the stuff not safe for polished aluminum made the wheels haze up real bad. I recommend Turtle Wax ICE All Wheel and Tire Cleaner. Works great and won't break the bank! Hope I could help.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
