e85 mpg drop
With the amount of drop in mpg in my 6.2 the price difference has to be $.70 a gallon cheaper for E-85 before I'm running it. I lose at least 3 if not 4 mpg running it and it beats the crap out of your engine oil too.
It's hardly ever a pay off around here, where I am. For a few weeks last summer is all it helped and if I got out of the city, I was screwed at finding it at the pump.
Last week Shell 93 was $3.37 a gallon. E-85? $3.09. Yeah, blow me a kiss next time Obama. LOL.
  • Replies 60
It's not apples and oranges for the 6.2, it's e85 or 93 hence the comparison
Ryan
i have been running ethanol free and cant tell a statistical difference over time. i have been running it for about the last 9 or 10 tanks and expected more. i hear E85 will feel the same or better than regualr gas on the ole butt dyno. not much around south GA to try, they just run it a good 10 percent in all fuel except a select few that carries ethanol free.....for boats, atvs, and so forth.
E-85 is for people who think they can save the planet. Does not make any sense to use it financially. I don't think they can even make it in the manufacturing process without a lot of help from the gov.
Nbs
You do know the gov subsidies have ended for e85
Also I do not run it as a green fuel so me it is performance and cost related
Ryan
Depressing to thing about how much gas has risen in a few weeks but as of this morning regular was $3.99/gal and E85 was 3.29. I filled up and blasted down 94 to drop my brother off at the airport and came right back and did a few in-town trips to pick up more stuff for the new apartment. DIC says 13.3 MPG right now and I was averaging just under 16 before the move. I let it idle lots in the morning and I have a heavy foot so my expectations are fairly low. Right now the cost difference means I about break even or maybe a marginal advantage with E85. But this is like ~150 miles into one tank so I got to keep it going longer. Not to mention the switch back to summer blends may change things too.
Yeah so I'm on my 3rd tank of E85 now. Truck absolutely has better throttle response and seems to idle smoother too. I also came up with 70 cents cheaper being the break even point but the range issue is killing me. I drove from my apt in MI to Purdue University and I had to buy gas on my way there. This will probably be my last tank of E85 for a bit. I'll start running it before any dunes trips but that's about it.
What were you doing down at Purdue?
Still here and will be till tomorrow most likely. I'm a field service tech for a company that makes lab equipment and I'm setting a machine up there this week.
Yup, I run it in the summer mostly but I have the same exact issue. If I run up to either of the properties up north, I'm screwed because nobody up that way sells it and one tank of E85 won't make it up there and back, for me.
Ah cool. I am about an hour south of Purdue.
Hey there is a family express right off I65 just out of west lafayette (I forget the exit number) that has E85 if you are looking. Also Meijer in town should have E85 too.
Interesting job.
Yeah Ryan two of the tanks were Meijier. There is one literally right up the road from my apartment and I stopped at one somewhere on I65. The other was outside Lansing, MI when I had dinner with some friends Monday evening. But like I said I'm going to go back to normal gas next fillup as this range issue is going to kill me.
$3.35 a gallon for corn fuel and $3.99 a gallon for 93 octane petrol up here. Stayed with 93 for now. Again, with the way that the 6.2 likes to drink E85, I've got to have a full $.70 spread just to break even let alone get ahead and it's rarely a $.70 difference here.
Heck, earlier in the winter, when fuel prices were around $3.39 a gallon, E85 was only $3.09. You'd be loosing money by running it.
E85 was $3.29/gal near me but it's now $3.35 I think. Like I said, I have to do lots of freeway driving now (next week I need to visit Champaign, IL, Detroit and Bowing Green, OH- all by Wednesday...) so the reduced range is just too much of an inconvenience. My last E85 tank (probably half city) was 11.36 MPG. Before that it was 12.76 and 12.3, which is about what I got on 87 towing the damn trailer out here from NH. :lol:
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
