New 2012 Black LTZ 6.2 Sitting in Lordstown?
My new 2012 Chevy Black LTZ 6.2 is sitting in Lordstown. Anyone know how long it will take to get to Pittsburgh?
  • Replies 41
Wish I could. I need to beat feb 29 deliverly date to get all my rebates including Pittsburgh Auto Show rebate. Dealer says it will be in time.
use google directions . It will give you directions and estimated time .
I know where lordstown is, but you cant pick up a vehicle there. has to arrive at the dealer.
Congrats on the new truck.
So you drive a 2011 Z71 and your also getting a 2012 LTZ. NICE!! :thumbs:
I will be trading the 2011 in on the 2012. It is the exact same truck but has the 6.2 and the 4 wheel disc brakes. It also has the brushed aluimun dash. the salesmans son wants my 2011 and with the supplier discount and the 3750 rebate I am trading up a year and to a 6.2 for 3000. my 2011 only has 5100 mile. just 5 months old.
Nice! very Nice!
You are going to love the 6.2
Well my neighbor has a Hemi Quad cab. I doubt he will even notice that I will have changed trucks. But he has enjoyed bragging about how his Hemi will dust my 5.3. I guess we will see what he has soon. LOL
If it has a vin I think they could do all the paperwork for you to buy and you would catch the rebates
Ryan
Yes you can!
Ryan
tell him your truck is still a 5.3 and race him
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 600 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
