I just run 2 10's. Sounds clean.
Sent from my DROID X2 using Xparent Red Tapatalk 2
I got two 10's also. They sound great.
Getting ready to switch my amps out. Boozaka to my Memphis one, I should put my Memphis 12" Mojo in, but I'll have no room if I do that.
Cleaned the truck and hooked the subs up in the bed
Subs in the bed?
I'm taking people in the dunes and we want subs so were rocking them In the bed so I can have passengers
A buddy of mine has a gull wing toolbox, was thinking it'd be cool to mount speakers to the underside of the wings, so when we're at the swimmin hole we could just pop open the toolbox, turn on a second amp, and be set. I think it's worth a shot. With his truck of course, I wouldn't get an over the rail box :lol:
Just finished unloading one load of portable fence panels 5 foot tall by 16 foot long had a bundle of 25 on the trailer went about 250 miles round trip to get them. Son's Tahoe took a crap on him so I unloaded his panels and then went to rescue him!! Tahoe is still on trailer will try and get a picture before it gets unloaded.:jester:
Hmmm...nothing too exciting today. Drove the truck to work, errands and back home again. She may get taken to the drive-in tomorrow night though.
Subs...hmmm I haven't used mine in quite a while. Maybe I should hook mine up that's in the basement.....
By the way what are the Dunes you speak of?
Tomorrow I'm hooking up to the horse trailer and taking 3 steers to get ear tagged for this years county fair
This is the dunes hahaha its a magical land where trucks quads dirtbikes and buggys (and some cars) roam free
this hole was up to his door handle deep
My buddy tim tried to help the buggy but got stuck so dustin with his 9" lifted ford f350 gets in there and im standing aside waiting to pull them all out hahaha dustin ended up getting them both out
test hill
beach
me in "big sexy" haha i was dancing
such a great day
Oil change , Inspection.
Then later on in the day noticed a 4" puddle of oil on the ground that was leaking from the skid plate.. So even after I payed someone to change the oil so i didnt have to get full of it.. I still had to get full of it cleaning off the skid plate and pressure washing the driveway :banghead:
When will I learn just to do it myself and not have to check on other peoples work / cleanup after it... :rant:
Truck is b!tching at me for an oil change. I hauled 2 steers and a heifer to get ear tagged for the fair and then took the heifer out of town to be inseminated because she has to be pregnant for the fair to be entered. Ill pick her up in a couple weeks. Ill be changing oil this week. Ordered the test kit from Blackstone late Tuesday night and got it Friday. They are fast.
Ive had 2 tests done by them so far.. my last one i requested another kit and they sent 5, lol.. I'm set for a while now.
My mechanic laughed at me and told me im wasting $ with the analysis but its piece of mind to me.
I know after every analysis i do not have coolant in oil..
I got 2 12's in mine and i everyone says its loud as hell but it sounds kinda quiet to me haha guess my hearing really is that bad...As far as working on my truck im going to try and crank the torsion bars some
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
