Any pics. in your beach wear????;)a post
kidding!
Sent from my iPhone4S
using Tapatalk
What a post, win.
went and bought an 18 pack. now about to pick up some pizza and take both to my cousins house. weekly poker game
kidding!
using Tapatalk
Stop lying you weren't kidding :lol:
Ryan
Got my travel trailer moving again so I can get it to the new house next week. Then cleaned the air filter (K&N) still letting it dry. Topped off the engine oil since it was a little low. Finaaly pulled driver side fog light that was full of water and sand to clean out the lens. Good day considering I had to work between rain storms.
4 hours of dunes was real nice out there the wind blew it all flat so i wasnt creeping around i actually got to let loose on the throttle some more and climb more hills
With the help of a friend I got my flag mount for Silver Lake painted and on the truck:
And debadged the tailgate:
Also swapped some 285s from his sisters truck onto mine and I can confirm a set of worn 285s barely, barely fit. We're talking millimeters between the fender liner and tire stuffed and turned. But they do fit!
your hole looks really small for some reason lol
Many guys prefer that. :P
Sent from my PIECE OF CRAP DROID X2 using Xparent Red Tapatalk 2
Sarah we talked about that as my friend and I both thought the same thing but it is a 1/2" hole which is what the flags are so I guess it will be a mystery till Friday! :lol:
I have purchased flags already made just to clamp on to my atv's rack. I used to play at the Pismo Beach dunes
Edited by chawkins6789
Nothing to clamp to on the front of the truck (and it has to be up front on trucks).
What's the difference in feeling from atv's and trucks in the dunes. Can't. Ride the atv's anymore because of my back. Thought of taking the toyota
Never rode an atv at the dunes but I have to imagine a truck is more comfy- full seat, less work to operate, quieter/smoother and you get air conditioning and a radio! :lol:
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
