Bumping it? That term is still in use? Dame we used that in the mid to late 90's when I was in high school
Ryan
I didn't know they used Dame in the 90s. :lol:
Lmao that plus monster had me run a 12 minute tote of knobs which is unheard of so you did a good thing
Sent from my truck using TAPATALK
2 hr drive home from school listening again
Sent from my DROID RAZR using Xparent Red Tapatalk 2
$400 on Amazon
It has sentimental value to me. i bought it as a birthday present to myself
That's like me and my truck I bought it for my birthday :) haha
Because the song has claimed another casualty. My brother shown me and I did it to my friend and now I mentioned it, you
Crap!, just watched the video. Hooked now:)
[quote name=chawkins6789' timestamp='13
51128845' post='1293071]
This thread is about to get locked and deleted to the depths of the earth :(
i have no idea what that songs about
Crotch thrusting. Duh!
:lol:
You said crotch :lol:
Ryan
What else would I call it? :lol:
you are all making me feel freaking old. I am freaking old, but that's beside the point. I thought that the Pink Floyd that I was listening to on the way home from work this morning was old school, I mean skool, I guess it must be stone tablet and abacus old school. Dang it. Skool. BTW it was Animals, 1977. I was twelve...
I was born in '84 but more and more things pop up that make me feel old. Mostly realizing how old some of the stuff I listened to in jr high is now. Or that the movie American Pie is like 13 years old now. Being an adult is a real drag sometimes. :lol:
Mike I feel you. I was born in 89. And some of the things now make me feel old. Like kids in elementary school walking around with iPhones. I didn't get a phone until high school and that was when a color screen was the big thing. Hell some of the things my brothers, who were born in 94 and 96, do and say make me fell old.
Who else is going to watch the video and join us?
Edited by chawkins6789
    • Hit mid 90's today. Even at the boarder of Canada and up by Duluth it was in the 90's. Going to be like this all week. Sure it's nothing like the south seeing 100's but they do say it's a different kind of heat here with all the lakes/water and humid days.
    • Pill flip on the transmission cooler lines is a 100% must do thing too.
    • It's a '21 and was a CPO with extended protection when purchased, so hopefully it will be covered.   I supposedly have all of it's service record history and nothing noted other than routine fluid changes, tire rotations, and the windshield washer nozzles replaced once.
    • I would argue that GMPartsDirect has that info wrong.    The service manual for R+R the lower arm and for adjusting camber/caster, none of the steps say to discard and replace the nut or the bolt.    The only part that gets discarded is the plastic cam adjustment retainer that is in the eccentric from the factory.     The LCA nut torque spec is:  First Pass: 180 Y (133 lb ft) Final Pass: 90 –105 Degrees   That is WELL past 130ft.lbs per the TSB that you reference that does not apply to this scenario.     As for your clunk.  I'd say it needs to be diagnosed thoroughly.  Assuming the LCA hardware is tight, you could have a problem with the UCA, sway bar end links, etc.
    • The filtering to wear relationship goes like this:      'Relative Engine Life "Factor" new divided by the factor old. So 8/3= 2.67. That result is the multiplier thus if a motor had an effective life of 100K using a filter with a 45 micron rating at a Beta ratio of 75 then a filter with a micron rating of 10 at a Beta of 75 would improve expected engine life to 267,000 miles.    Wear metals are an indirect indicator. Less is better and the motor lives longer but there isn't a multiplier like there is for filtration so well documented. Most of that has to do with the sensitivity of the wear metals tests themselves. They read a 'slice' of the spectrum but not the absolute values for the entire spectrum. So a general indicator that is used WITH the results of other tests. Two others considered in this post. Trending is very important.    There is also the influence of corrosive wear which may be seen in the wear metals but separate from load based or viscosity mitigated indication. It's a small graph but the gray line is wear vs the TBN/TAN crossover. Not as useful as it used to be as there are now new chemistries for acid remediation that don't show up in standard UAO testing. They will catch up or be found liars. Only two possible outcomes, eh?
