Got the tires rotated, the oil changed and the emissions test done.
Sent from my DROID RAZR using Tapatalk 2
An XL. Trying to decide on whether or not I want a 2013 or wait for 2014s.
Your Denali isn't an XL? I thought it would be. Most Denali's I see are XL
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Tried to fill my truck but it stopped me at $100. Close to full but not quite
Matt- nice. Chris- not nice. That's why I fill up at about a quarter tank. Doesn't of course change what I'm paying overall but it doesn't feel as painful for some reason.
Edited by SILVERADOSC540
wait for the 14's!!!! unless you want a 13, you will be able to get a really good deal on the 13's with the new style coming out soon
also planning on new truck soon! with 145k on the odo.. its about that time
The 13s are also appealing as all my mods will swap over, including the TVS2300 that hasn't been installed yet. Plus, don't really want to deal with any "bugs" that the 2014s will have to work through.
cleaned all the sand out of its vagina and threw on some new rims n tarz
545917_10200926323901367_1517348503_n.jp
537945_10200926321181299_1722772854_n.jp
483457_10200926389383004_1612242590_n.jp
Get a '14 so I can get my hands on a used Wildwood kit
Yes but it just stays in the household. I would pay so there's extra money. I do need to get with you some time on some quotes
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,264 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
