On the camaro forum I am on people are raving over vmax throttle bodies. I am tempted to get one. $150
Off of a 6.0 truck motor? How many mm are they?
I have heard the silver blade LS2 is good for F/I
No they are the stock throttle bodies ported. I forget offhand what size. You have to pay a core charge so they can keep the supply going
Still only a 90mm. For FI, it is only a concern if air is being forced through the throttle body rather than pulled, like a Magnacharger.
Sent from a jelly bean.
Edited by Jennabear
Getting the exhaust fixed. One of the tips have broke loose and the rattle is driving me nuts
Sent from my SGH-I927 using Tapatalk 2
Drove it 1,049 miles to and from Virginia(30 min south of Richmond) wed-today. I avg'd 19.7 mpg and 1.25 qts of Mobil 1 lol.
Installed new Pro-Comp ES9K's on the front. Tightest fitment in a truck I have ever seen/done. Really, they do not fit trucks with 2wd coil springs with 2.5in spacers like they claim. But, they did firm the ride up which is what I was looking for so time will tell.
At the lake
My truck and my cousins
Dog went swimming
Ryan
I was sneeking around the GM dealer lot in my neighborhood again.
Looked at the new arivals of double cabs.
Climbed into the cabin and played on the knobs.
It's like "self punishmend" to resist the desire to go inside and grab the salesman.
so long
j-ten-ner
I thought all gen 4's had either 87 or 90 mm throttle bodies.
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
My son actually fished with a lure for the first time :)
Ryan
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
