Ran into another problem with the lift yet again, beginning to wonder if it was even worth installing now
Yes that is the torsion bar drop bracket and it won't fit on one side. WTF
Just put about 240 miles on my truck for a doctors appt
Sent from my Samsung Galaxy S4 using Tapatalk 4
Been enjoying the hell out of my rental Suburban. We've been using it to take everyone to lunch the past couple days. Rides so nice for such a big vehicle with those coils out back.
Lifts require a lot of work to install not all just bolt right up
It ain't my first rodeo with a lift on this truck but the last one wasn't this difficult. They need to overnight me some new brackets. Bad enough I had to wait 3 weeks for the lift to come in and now this. And watch the new ones will be delayed for powder coating just like the kit
Sitting at the dealer waiting on an alignment
Best spot at the mall
Got home from the mall to this
Got home from the mall to this Sent from my Samsung Galaxy S4 using Tapatalk 4
Them hedges need some trimming!!!
Ill let my landlord know
Ill let my landlord know Sent from my Samsung Galaxy S4 using Tapatalk 4
I am just jealous of all the green in your pictures, everything here is turning colors and falling off the trees. Which means it's almost time to put the Harley away for a few months
Here we have 9 months of summer, 2 of winter, 2 weeks of fall and 2 weeks of spring
Got the tires installed. Rides so smooth at 80 mph now. But my right sides were done.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
